manant 57 #1 Posted April 23, 2021 The mower blades for my 48" mower deck no 65-48ms01 seem impossible to find. The 3 blade kit part number is 100202 and the blades have a double d center hole and two side holes for pins. Would it be safe to remove the 1/4" spirol pins from the spindle and use a blade with a 3/4"round center hole using a cupped washer and standard bolt? Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #2 Posted April 23, 2021 Check with K & B in our vendor section they may have a set of D D blades. Share this post Link to post Share on other sites
manant 57 #3 Posted April 23, 2021 Thanks, I looked at K&B but did not see any. I posted a request to them but no reply yet. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #4 Posted April 23, 2021 Wonder if the blades are too hard to drill so the pins would still drive them? Use 106637 3-blade set (3/4" round hole) Garry 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted April 23, 2021 1 hour ago, manant said: Thanks, I looked at K&B but did not see any. I posted a request to them but no reply yet. @76c12091520h Share this post Link to post Share on other sites
Jeff-C175 7,207 #6 Posted April 23, 2021 (edited) 1 hour ago, manant said: deck no 65-48ms01 Is that a typo? should that be 05-48MS01 ? Are they really the double D ? maybe that is the correct number I don't know. [never mind! I see that is a good number, disregard please.] I can tell you that the blades for my 05-48MS01 from 1980 are in fact 3/4" hole and easily found. Edited April 23, 2021 by Jeff-C175 my bad Share this post Link to post Share on other sites
daveoman1966 3,881 #7 Posted April 23, 2021 My old reliable source has the set of 100202 blades...About $50 bux....check it out: https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO//100202/1/ 1 Share this post Link to post Share on other sites
manant 57 #8 Posted April 23, 2021 Thanks daveoman! I have been looking all over for these with no luck until I clicked on your link. I have ordered them - about $60 including shipping. Thanks again. 1 Share this post Link to post Share on other sites
76c12091520h 4,003 #9 Posted April 24, 2021 5 hours ago, gwest_ca said: Wonder if the blades are too hard to drill so the pins would still drive them? Use 106637 3-blade set (3/4" round hole) Garry Can be done; we've done it successfully. Just make sure to retain the 1336 blade washer when doing so. We have a fully outfitted machine shop at our disposal so we're a little more spoiled than most when it comes to things like this. Share this post Link to post Share on other sites
manant 57 #10 Posted April 27, 2021 DANG! I just got a call from Pat's Small Engine Plus saying the blades are no longer available and they are refunding my $60. I am still looking. Share this post Link to post Share on other sites
daveoman1966 3,881 #11 Posted April 28, 2021 8 hours ago, manant said: DANG! I just got a call from Pat's Small Engine Plus saying the blades are no longer available and they are refunding my $60. I am still looking. I may have a decent set of DD blades for the 48" deck....not sure. Will check in the daylight am and let you know. BTW...contact me easier via email. I am: daveoman@windstream.net Share this post Link to post Share on other sites
