Joecxp 1 #1 Posted April 21, 2021 Hello everyone, I am looking for a replacement deck for my 1972 Commando 8. The one I have is rusted through. Are there other decks from other years and models that will work? I currently have a 36 inch rear discharge deck. Any help is much appreciated!!! Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted April 21, 2021 Rusted through such that welding in some patches wouldn't be a solution? You might have better luck posting a wanted ad in the classified section. Share this post Link to post Share on other sites
oliver2-44 11,272 #3 Posted April 21, 2021 @Joecxp show us some pictures of the deck. There maybe a repair option Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #4 Posted April 21, 2021 The mower listed in 1972 is 5-0620 Medium frame tractors require 102607 drive belt. Blades with 3/4" center hole are readily available. 5/8 x 3/4" maybe not available. Mower DNA 1972 model 5-0620 replaced by 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted April 21, 2021 (edited) 2 hours ago, Joecxp said: currently have a 36 inch rear discharge If it's not a requirement that you stay with the 36 RD, you can also go with side discharge. If I were looking for a newer deck I would try to find the newer one with the 17mm bearings as those are MUCH more readily available, as are the blades with the 3/4 hole as opposed to the double D type Edited April 21, 2021 by Jeff-C175 Share this post Link to post Share on other sites
Joecxp 1 #6 Posted April 21, 2021 31 minutes ago, Jeff-C175 said: If it's not a requirement that you stay with the 36 RD, you can also go with side discharge. If I were looking for a newer deck I would try to find the newer one with the 17mm bearings as those are MUCH more readily available, as are the blades with the 34 hole as opposed to the double D type Share this post Link to post Share on other sites
Joecxp 1 #7 Posted April 21, 2021 Di you mean like the decks on the 310-8's and so on? Share this post Link to post Share on other sites
Jeff-C175 7,207 #8 Posted April 21, 2021 (edited) 1 hour ago, gwest_ca said: mower listed Garry, are you saying that all those decks will fit Joe's machine? @Joecxp See Garry's DNA list. There's your answer I think. Edited April 21, 2021 by Jeff-C175 Share this post Link to post Share on other sites
Joecxp 1 #9 Posted April 21, 2021 11 minutes ago, Jeff-C175 said: Garry, are you saying that all those decks will fit Joe's machine? @Joecxp See Garry's DNA list. There's your answer I think. I don't see Garry's answer. Share this post Link to post Share on other sites
Joecxp 1 #10 Posted April 21, 2021 13 minutes ago, Jeff-C175 said: Garry, are you saying that all those decks will fit Joe's machine? @Joecxp There's your answer I think. Share this post Link to post Share on other sites
Joecxp 1 #11 Posted April 21, 2021 I got it. Thanks guys!! Big help! 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #12 Posted April 21, 2021 1 minute ago, Joecxp said: I don't see Garry's answer. Post #4, gwest is Garry. He posted a list. Share this post Link to post Share on other sites
Joecxp 1 #13 Posted April 21, 2021 23 minutes ago, Jeff-C175 said: Garry, are you saying that all those decks will fit Joe's machine? @Joecxp There's your answer I think. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #14 Posted April 22, 2021 On 4/20/2021 at 10:51 PM, Joecxp said: Yes they all fit except the medium frame length tractors require a shorter drive belt than what may be listed in the ipl. They did not expect us to be running the same tractors 50 years later. The DNA list was taken from the Attachment Interchange with an improvement. The list shows 1 the original decks, 2 the deck that replaced the original deck and 3 the deck that was available in 2000 when the list was made. I added the decks between the last two. Garry 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #15 Posted April 22, 2021 (edited) 1 hour ago, gwest_ca said: medium frame length Garry, I've seen this term used many times but am not sure which is short, medium, or long frame. Can you expand on that a bit at the risk of slightly off topic? Thanks! @Joecxp as a "by the way" Joe, in the deck listing, as an example, the MR in the listing indicates REAR discharge. SIDE discharge are MS. I'm not sure if the 36 is available in SIDE discharge, but if it is, it would be 05-36MS02 Edited April 22, 2021 by Jeff-C175 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #16 Posted April 22, 2021 Hope I have them all listed here Drive belt 102607 (1/2" x 89.12") when used on medium frame 43-1/2" wheelbase tractors 1972 Commando 800 model 1-0110 1973 8hp 4-Speed models 1-0120 and 1-0130 1974 B-80 4-Speed models 1-0140 and 1-0145 1974 B-100 Auto model 1-0510 1975 B-80 4-Speed model 1-0141 1975 B-100 Auto model 1-0511 Drive belt 102741 (1/2" x 96.6") for B-Series & C-Series long frame tractors with 45-1/2" wheelbase Short frame tractors have a 41-1/4" wheelbase Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #17 Posted April 22, 2021 I did miss one model 1-0130. Not sure if it is a 1973 or 1974 model and may be a Belgium built model for Europe and may have been named a Commando for that market. Garry 1 Share this post Link to post Share on other sites
Joecxp 1 #18 Posted April 22, 2021 On 4/20/2021 at 9:40 PM, Jeff-C175 said: If it's not a requirement that you stay with the 36 RD, you can also go with side discharge. If I were looking for a newer deck I would try to find the newer one with the 17mm bearings as those are MUCH more readily available, as are the blades with the 3/4 hole as opposed to the double D type So I found the model number on my deck. It is a 50620. Unfortunately, the deck is too far gone for repair. What is a newer deck that I can replace it with that I can still find parts for? From what tractor? Thanks! Share this post Link to post Share on other sites
Jeff-C175 7,207 #19 Posted April 23, 2021 (edited) 1 hour ago, Joecxp said: What is a newer deck that I can replace it with that I can still find parts for? From what tractor? I think Garry's posts have answered that Joe. He gave a list of decks that will fit and later explained the belt differences. Go back and look at his posts. Get the newest one from his list that you can find, most preferably with the blades that use the 3/4" hole and spindles that take the 17mm bearing as these are easy to obtain and much cheaper. You'll need the belt that Garry listed. So that means 1983 or newer. Further, it doesn't HAVE to be a REAR discharge, nor does it HAVE to be a 36" deck. You can run a 42" or a 48" if you find one. Edited April 23, 2021 by Jeff-C175 Share this post Link to post Share on other sites
