RJ Hamner 1,025 #1 Posted April 12, 2021 Working on the single bbl carb for a 20 hp Kohler. It was running way too rich and erratic. Ordered a rebuild kit, soaked it, scrubbed it, spray carb cleanered all the knooks and crannies, blew it out with hp air. New O rings and gaskets. Results ......started right up, let it idle for a bit while it evened out. Slowly opened the throttle. Every thing was fine till I went to full throttle. It stumbled and quit. Tried it several times same result. Before I tear it down again.....any ideas on what I am looking for??? Carburetors are NOT my strong point. Bob Share this post Link to post Share on other sites
WHX?? 52,908 #2 Posted April 12, 2021 Fiddle with the mixture screws Bob ...... manual on initial settings here. Carburator Reference Manual TP-2377-E.pdf 2 Share this post Link to post Share on other sites
Pullstart 68,183 #3 Posted April 12, 2021 Just before it starts to stumble, pull the choke a bit. If it gets worse, you’re still too rich. If it gets better, you need more fuel. 4 1 Share this post Link to post Share on other sites
squonk 44,629 #4 Posted April 12, 2021 Richen it up a bit. Sounds lean. There must be a high spped mixture screw on there somewhere. Share this post Link to post Share on other sites
RJ Hamner 1,025 #5 Posted April 12, 2021 1 hour ago, WHX24 said: Fiddle with the mixture screws Bob ...... manual on initial settings here. Carburator Reference Manual TP-2377-E.pdf 3.29 MB · 1 download Sorry to say but there are no mixture screws. The only adjustment is the screw on the throttle rod Share this post Link to post Share on other sites
RJ Hamner 1,025 #6 Posted April 12, 2021 I know that I will probably have to spend time in Wheel Horse purgatory but..... This is on a 2006 GT2500 Cub Cadet that has the “idiot proof” can adjust nothin carburetor. Other than idle speed the only adjustment I can find is the float height. Share this post Link to post Share on other sites
WHX?? 52,908 #7 Posted April 12, 2021 9 minutes ago, RJ Hamner said: 2006 GT2500 Cub Cadet Family site here Bob you shouldn't be using foul language.... silly me thinkin you was on a horse! Try what Kev suggested that will narrow it down to too lean. Any fuel pump, if has one is fubar or fuel lines tank plugged? 1 1 Share this post Link to post Share on other sites
JoeM 8,904 #8 Posted April 12, 2021 Just repaired neighbors 25HP ariens. After looking at the parts cost ended up getting a knock off. It was real strange the knock off and OE were identical. I do need to ask, it has one of those anti backfire solenoid on the bowl? I would test it if the choke test proves it is to lean. Send me a pic of the carb. if you can. I might have one off of a single jug 20hp courage that you might have for a cup of coffee! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #9 Posted April 12, 2021 I use this to soak em down. Then the ultra sonic cleaner. 2 Share this post Link to post Share on other sites
RJ Hamner 1,025 #10 Posted April 12, 2021 Just now, The Tuul Crib said: I use this to soak em down. Then the ultra sonic cleaner. I use the NAPA version 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #11 Posted April 12, 2021 Good stuff!! Sure does stink!! Share this post Link to post Share on other sites
RJ Hamner 1,025 #12 Posted April 12, 2021 13 minutes ago, WHX24 said: Family site here Bob you shouldn't be using foul language.... silly me thinkin you was on a horse! Try what Kev suggested that will narrow it down to too lean. Any fuel pump, if has one is fubar or fuel lines tank plugged? That comment about fuel lines got me to thinking. I use a mini visegrip to crimp the fuel lines. With the stuff I normally use it’s not a problem. I remember thinking that the fuel line on the cub was pretty heavy duty. And it’s 15 years old??? Maybe it didn’t unscripted totally??? Worth a check! 2 Share this post Link to post Share on other sites
RJ Hamner 1,025 #13 Posted April 12, 2021 21 minutes ago, JoeM said: Just repaired neighbors 25HP ariens. After looking at the parts cost ended up getting a knock off. It was real strange the knock off and OE were identical. I do need to ask, it has one of those anti backfire solenoid on the bowl? I would test it if the choke test proves it is to lean. Send me a pic of the carb. if you can. I might have one off of a single jug 20hp courage that you might have for a cup of coffee! Is there anything you DON’T have? I think you just want your K Cup back 3 Share this post Link to post Share on other sites
oliver2-44 10,978 #14 Posted April 12, 2021 My Weed Eater had an idiot proof non adjustable carb. It had factory adjustment screws down in recesses that had been filled with a hard wax type filler. I was able to clean the filler out and got usable adjustment screws. Take a close look at your carb and see if anything looks filled over Share this post Link to post Share on other sites
RJ Hamner 1,025 #15 Posted April 12, 2021 2 hours ago, pullstart said: Just before it starts to stumble, pull the choke a bit. If it gets worse, you’re still too rich. If it gets better, you need more fuel. Tried that with the same result Tried replacing the fuel line.... no change Tested fuel pump ... no problems with the pump. Nice 6 inch arc to the garage floor Just spent $38 on ebay for an aftermarket New from Kohler = $200 (probably made by the same outfit that makes the ebay one) And if that don't work.......I'll be callin' ya Joe 1 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #16 Posted April 12, 2021 @WHX24Thanks for the carb info JimBob only 60 pages should have looked at that before I hit print , now you owe me a print cartridge or the money for one . Where should I mail a copy of the invoice ? 4 Share this post Link to post Share on other sites
squonk 44,629 #17 Posted April 12, 2021 32 minutes ago, elcamino/wheelhorse said: @WHX24Thanks for the carb info JimBob only 60 pages should have looked at that before I hit print , now you owe me a print cartridge or the money for one . Where should I mail a copy of the invoice ? You go thru carburetors like pullstart goes thru band-aids! If I had a way to activate your printer from here I'd send some Quadrajet manuals to your printer! 2 Share this post Link to post Share on other sites
