Ff717 1 #1 Posted April 10, 2021 I have a 314-8 with a Kohler. Toward the end of last summer the engine started cutting in and out. When the engine us warm it is much worse. We replaced the manual fuel pump on the front of the motor. Have a clean fuel and air filter. Have loosened gas cap with no change. Wonded if anyone has experienced anything close. Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted April 10, 2021 Does that engine have a CONDENSER. If so, replace it. As the condenser ages, it begins to fail when warmed up. 1 Share this post Link to post Share on other sites
953 nut 64,127 #3 Posted April 10, 2021 Could be an electrical connection that needs to be tightened or cleaned or it may be fuel related. Gas with ethanol will slowly screw up your fuel system, to find a station that sells ethanol free gas use this site. https://www.pure-gas.org/ Post the Model Number of your 314 and we can take a look at the wiring system to see what components could be the culprit. 1 Share this post Link to post Share on other sites
edgro 680 #4 Posted April 11, 2021 Check screen on fuel fitting in tank. I had one do something like that, the screen was plugged or severely restricted. Would mow for 1/2 hour or so, then start cutting out Share this post Link to post Share on other sites
Ff717 1 #5 Posted April 11, 2021 Thanks guys for the input when I get back to the garage I'll post the model # and I'll also check the shutoff valve and the 314 i have is electronic ignition. Again thanks & will get back with y'all in a day or so. 1 Share this post Link to post Share on other sites
Mower Man 9 #6 Posted April 11, 2021 Check your motor mounting bolts. Is the engine bolted securely on the tractor frame? Have any broken or loosened? No movement is best. Share this post Link to post Share on other sites
