Jodell222 0 #1 Posted April 9, 2021 I just recently purchased a 520-8 wheel horse. Can anyone tell me what type of snow blower is compatible for this model? Share this post Link to post Share on other sites
rjg854 12,639 #2 Posted April 9, 2021 I think 🤔 any model made in the 70's and newer will work. Others will be along with specifics. 1 Share this post Link to post Share on other sites
oliver2-44 11,075 #3 Posted April 9, 2021 The 530-8 is a great horse, there were only a limited number of 520's made with the 8 speed, the large majority have hydro transmissions. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #4 Posted April 9, 2021 Single stage models Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) 2002-2007 model 79362 The is also a 2-stage snowthrower. The D&A file here lists all the attachments Garry 1 Share this post Link to post Share on other sites
