muz123 1,193 #1 Posted April 9, 2021 The 280 hour KT17 in my 417 is all of a sudden blowing oil out of the dip stick tube while it is running. What could be the issue? A breather? Thanks Share this post Link to post Share on other sites
8ntruck 8,606 #2 Posted April 9, 2021 Breather sounds like a good place to start. What kind of fuel pump do you have? Might be possible that the fuel pump is leaking gas into the crank case, raising the oil level, causing extra splashing. Check the consistency of the oil and the oil level. Gas in the oil is bad - to the point it can take out the engine. 3 1 Share this post Link to post Share on other sites
Pullstart 68,883 #3 Posted April 9, 2021 Is it running alright otherwise? Too much crankcase pressure... possibly a piston/ring issue? 2 Share this post Link to post Share on other sites
953 nut 64,127 #4 Posted April 9, 2021 9 hours ago, muz123 said: all of a sudden If this were a gradual change I would suspect the breather. As stated above, check the oil level and run a compression check or a cylinder leak-down test. 1 1 Share this post Link to post Share on other sites
pacer 3,179 #5 Posted April 9, 2021 While fuel could have entered the crankcase, I have reservations about that. With your saying "all of a sudden" to me would indicate a more serious problem in that a piston has --- had a problem? allowing pressure to enter the case and cause the "old faithful" 1 1 Share this post Link to post Share on other sites
muz123 1,193 #6 Posted April 10, 2021 On 4/9/2021 at 6:39 AM, 953 nut said: If this were a gradual change I would suspect the breather. As stated above, check the oil level and run a compression check or a cylinder leak-down test. Removed the breather and it was covered in oil. Share this post Link to post Share on other sites
muz123 1,193 #7 Posted April 10, 2021 (edited) On 4/8/2021 at 9:48 PM, pullstart said: Is it running alright otherwise? Too much crankcase pressure... possibly a piston/ring issue? Yes it runs good, just sputters at different engine speeds and puffs blue smoke now, and has lots of blowby. Edited April 10, 2021 by muz123 Share this post Link to post Share on other sites
lynnmor 8,628 #8 Posted April 11, 2021 3 hours ago, muz123 said: puffs blue smoke now, and has lots of blowby. Time for an autopsy. Share this post Link to post Share on other sites
oliver2-44 11,214 #9 Posted April 11, 2021 With it running pull one plug wire, the reconnect and pull the other. See if that will tell you anything about one of the cylinders 2 Share this post Link to post Share on other sites
