The Tuul Crib 7,339 #1 Posted April 8, 2021 Anyone familiar with the Intek 22 hp Briggs motor. It hesitates to crank when starting but does start eventually. Is this a valve adjustment on these motors? If so what are the adjustments supposed to be on this motor? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #2 Posted April 8, 2021 Post the model and code numbers. We may have a manual. Some the valve adjustment is critical for the compression release to work. Garry Share this post Link to post Share on other sites
The Tuul Crib 7,339 #3 Posted April 9, 2021 59 minutes ago, gwest_ca said: Post the model and code numbers. We may have a manual. Some the valve adjustment is critical for the compression release to work. Garry Thanx Gary! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #4 Posted April 9, 2021 The B&S manual you need is 273521 and we do not have it. Sorry Garry Share this post Link to post Share on other sites
The Tuul Crib 7,339 #5 Posted April 9, 2021 46 minutes ago, gwest_ca said: The B&S manual you need is 273521 and we do not have it. Sorry Garry Thanks for tryin Gary I appreciate it! Share this post Link to post Share on other sites
Stepney 2,354 #6 Posted April 9, 2021 Yes, these do have adjustable rockers. And they need adjusting about every 2-400 hours.. or else this happens. Done quite a few myself. Share this post Link to post Share on other sites
jhn9840 35 #7 Posted April 9, 2021 Valve clearance intake and exhaust cold - .004-.006 Hope that helps you. jhn9840 John 1 Share this post Link to post Share on other sites
Tuneup 1,452 #8 Posted April 9, 2021 Yeah, went through this on the snapper 11 Intek. The compression was strong enough to barely allow a pull start. It's a beast! Forget the starter. Simple valve adjustment. Share this post Link to post Share on other sites
The Tuul Crib 7,339 #9 Posted April 9, 2021 The tractor has 450 hrs on it so i guess its time for a valve adjustment. Its a real smooth running motor with not a bit of smoke. Customer wants another year out of it and thinking way more than that. Share this post Link to post Share on other sites
