krohs nest 29 #1 Posted April 7, 2021 Finishing up my GT-14 rebuild (finally close to the end) what is the best route to run the throttle. Pictures would be great. Thanks Guys. Share this post Link to post Share on other sites
peter lena 9,898 #2 Posted April 7, 2021 KROHS NEST, don,t have any pictures , others will show you those, recommend you add more cable clamps like these to your set up , https://www.grainger.com/product/KMC-Cable-Clamp-481Y33 only use this for a picture reference , your local h/w store should have them in the small pull out drawer section . thoroughly pre lubricate the cable to verify operation , and add clamps to make it a smooth solid control point , pete Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted April 7, 2021 I'm assuming you were talking about a big block engine. This is the only picture I have of the way I ran mine. 1 Share this post Link to post Share on other sites
krohs nest 29 #4 Posted April 10, 2021 On 4/7/2021 at 1:27 PM, The Tuul Crib said: I'm assuming you were talking about a big block engine. This is the only picture I have of the way I ran mine. Share this post Link to post Share on other sites
krohs nest 29 #5 Posted April 10, 2021 You guys are amazing, just what I needed. Thanks again Share this post Link to post Share on other sites
