krystolo 504 #1 Posted April 2, 2021 Checking over Rosie tonight and I see that the engine attachments don’t quite match up. Suspect a swap at some point in her life. Opinions? Share this post Link to post Share on other sites
cschannuth 3,817 #4 Posted April 2, 2021 There should be a J bolt through there holding it down to the frame. 1 1 Share this post Link to post Share on other sites
krystolo 504 #5 Posted April 2, 2021 11 minutes ago, cschannuth said: There should be a J bolt through there holding it down to the frame. Should there be J bolts all around, or just on one side? Here’s the other side. Share this post Link to post Share on other sites
Ed Kennell 41,771 #6 Posted April 2, 2021 There should be two bolts inside the right frame rail into two tapped holes in the pan. 2 7 1 Share this post Link to post Share on other sites
cschannuth 3,817 #7 Posted April 2, 2021 1 hour ago, krystolo said: Should there be J bolts all around, or just on one side? Here’s the other side. On my charger 12 they used two J bolts on the side that overhangs the frame and two regular bolts on the other side. I didn’t even think about the fact that they would put a bolt up through the bottom of the frame into a threaded hole in the bottom of the engine but that makes sense. 4 Share this post Link to post Share on other sites
ebinmaine 72,363 #8 Posted April 2, 2021 2 hours ago, Ed Kennell said: There should be two bolts inside the right frame rail into two tapped holes in the pan. 2 Share this post Link to post Share on other sites
OldWorkHorse 3,093 #9 Posted April 2, 2021 (edited) 9 hours ago, ebinmaine said: Learned that the hard way! Always thought just 2 bolts held the engines on my horses... till I tried winching a engine off after removing the 2 bolts you can see and the frame still lifting with the motor! That's how I found the 2 hidden bolts! Edited April 2, 2021 by OldWorkHorse 3 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,437 #10 Posted April 2, 2021 The engine has the correct spec number and Kohler built it in 1977. The tractor was scheduled to be built 008165 - Build date 1977 7066 March 07 Monday Garry 2 1 1 Share this post Link to post Share on other sites
Tuneup 1,451 #11 Posted April 2, 2021 I didn't notice that offset with the '77 120 until I went to reinstall the engine and scratched my head for a while. It doesn't fit any other way. Call it a big block and be happy with it 1 1 Share this post Link to post Share on other sites
953 nut 59,734 #12 Posted April 2, 2021 8 hours ago, Ed Kennell said: There should be two bolts inside the right frame rail into two tapped holes in the pan. This is what the oil pan looks like from below. 9 1 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #13 Posted April 2, 2021 10 minutes ago, 953 nut said: This is what the oil pan looks like from below. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #14 Posted April 2, 2021 I did the same thing when I got my first horse. It looked a little odd because I thought once It wasnt bolted down. I have even drilled holes now in oil pans and threaded the holes just for this purpose. Share this post Link to post Share on other sites
krystolo 504 #15 Posted April 2, 2021 2 hours ago, Tuneup said: I didn't notice that offset with the '77 120 until I went to reinstall the engine and scratched my head for a while. It doesn't fit any other way. Call it a big block and be happy with it HAHA! I just thought it was odd that it looks like it doesn't belong there. I'm thrilled with her! Just love her to pieces. Well, hopefully not to pieces. LOL 1 2 1 Share this post Link to post Share on other sites
ebinmaine 72,363 #16 Posted April 2, 2021 Just now, krystolo said: I'm thrilled with her! Just love her to pieces. Well, hopefully not to pieces. LOL It's okay if you love it to pieces as long as you put most of them back... 3 Share this post Link to post Share on other sites
krystolo 504 #17 Posted April 2, 2021 Just now, ebinmaine said: It's okay if you love it to pieces as long as you put most of them back... My skills, are still... er... "developing" in that area, so big pieces for now. Easy pieces. Like a toddler puzzle. 1 2 Share this post Link to post Share on other sites
ebinmaine 72,363 #18 Posted April 2, 2021 Just now, krystolo said: My skills, are still... er... "developing" in that area, so big pieces for now. Easy pieces. Like a toddler puzzle. No worries. We all start somewhere. 1 Share this post Link to post Share on other sites
clueless 3,222 #19 Posted April 2, 2021 Looks to me like Rosie still got her original equipment . 1 Share this post Link to post Share on other sites
stevasaurus 23,274 #20 Posted April 2, 2021 This Case is solved. 2 3 Share this post Link to post Share on other sites
Mikey the Monkey 700 #21 Posted April 2, 2021 (edited) @krystoloLooks like maybe you should put in a want ad for the top engine tin to help with keeping the head cool. Unless you just temporarily removed it. Edited April 2, 2021 by Mikey the Monkey 3 1 Share this post Link to post Share on other sites
krystolo 504 #22 Posted April 2, 2021 (edited) 20 minutes ago, Mikey the Monkey said: @krystoloLooks like maybe you should put in a want ad for the top engine tin to help with keeping the head cool. Unless you just temporarily removed it. Dumb question... what is that? ohhh! Is see! A little cap over the fins. So that helps keep it cool? Edited April 2, 2021 by krystolo 1 Share this post Link to post Share on other sites
ebinmaine 72,363 #23 Posted April 2, 2021 15 hours ago, krystolo said: 6 minutes ago, krystolo said: Dumb question... what is that? ohhh! Is see! A little cap over the fins. So that helps keep it cool? The whole top of the engine in the picture just above this should be covered with a piece of sheet metal If you don't have one on there it would be a great idea to procure one ASAP from either one of our members or a to z in Pennsylvania 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #24 Posted April 2, 2021 48 minutes ago, stevasaurus said: This Case is solved. Wow she looks like one of the munsters! 1 1 Share this post Link to post Share on other sites
WHX?? 51,688 #25 Posted April 2, 2021 (edited) Some one swapped the head out. It should have what we call a high boss head meaning where the head bolts are then even with the top of the fins. So the head tin goes like this. Last pics is a low boss head with all sorts of PO goofyness goin on. Edited April 2, 2021 by WHX24 1 Share this post Link to post Share on other sites
