Erby 15 #1 Posted March 20, 2021 the drive shaft on the right hand side has a gap between the axle housing and the back of the wheel ,f i push the wheel in then the drive shaft protrudes from the wheel Share this post Link to post Share on other sites
squonk 44,813 #2 Posted March 20, 2021 Sounds like you have a loose/worn wheel hub. There should be 1 or 2 set screws on the hub. Take them out and see if the hub will just slide off. You need to inspect the key and axle keyway for damage. Share this post Link to post Share on other sites
953 nut 62,715 #3 Posted March 20, 2021 There should be two set screws with locking nuts to position the hub on your axle. If they have been loose for a while I would suggest removing and inspecting the hub and axle key. Mike posted while I was typing. Share this post Link to post Share on other sites
Erby 15 #4 Posted March 20, 2021 Thanks for your reply I have taken the wheel off and the hub/wheel flange is sliding on the axle shaft the set pin is very tight im afraid it might shear with more effort Share this post Link to post Share on other sites
squonk 44,813 #5 Posted March 20, 2021 Take the hub off and inspect the hub innards and the axle. Sounds like something is damaged Share this post Link to post Share on other sites
Erby 15 #6 Posted March 20, 2021 all sorted now got the hub off shaft and key way ok refitted and is now fine. thanks again speak to all soon Erby. 1 Share this post Link to post Share on other sites
