ChrisHarkin 1 #1 Posted March 19, 2021 Has anyone experienced starter motor trouble where it sounds like its trying to engage with the flywheel teeth it eventually does and starts the engine. But the noise it makes is horrible and could eventually perhaps cause damage to either the pinion or flywheel. Share this post Link to post Share on other sites
Pullstart 68,181 #2 Posted March 19, 2021 1 hour ago, ChrisHarkin said: Has anyone experienced starter motor trouble where it sounds like its trying to engage with the flywheel teeth it eventually does and starts the engine. But the noise it makes is horrible and could eventually perhaps cause damage to either the pinion or flywheel. Is there a way you could upload a video of the noise and action to YouTube and share it here? Share this post Link to post Share on other sites
Achto 29,850 #3 Posted March 19, 2021 1 hour ago, ChrisHarkin said: Has anyone experienced starter motor trouble where it sounds like its trying to engage with the flywheel teeth it eventually does and starts the engine What kind of engine?? if it is a Kohler, chances are that your starter drive is getting bad, If it is a Briggs, then the plastic gear on the starter drive is stripped out. 1 Share this post Link to post Share on other sites
Lane Ranger 11,629 #4 Posted March 19, 2021 I wish the Magnum motors had an easier access to the starters! The Bendix head on those starters seems to get noisy or does not engage well more than most of my Kohlers. I have to take off the front motor tin to place graphite on the Bendix. Not an easy job! 1 Share this post Link to post Share on other sites
Stormin 9,986 #5 Posted March 19, 2021 My guess is the bearing/bush at the Bendix end of the motor badly worn. I've just replace that bush on three motors. Share this post Link to post Share on other sites
ChrisHarkin 1 #6 Posted March 19, 2021 2 hours ago, pullstart said: Is there a way you could upload a video of the noise and action to YouTube and share it here? Share this post Link to post Share on other sites
ChrisHarkin 1 #7 Posted March 19, 2021 Will try and get a video tomorrow Share this post Link to post Share on other sites
ChrisHarkin 1 #8 Posted March 19, 2021 1 hour ago, Lane Ranger said: I wish the Magnum motors had an easier access to the starters! The Bendix head on those starters seems to get noisy or does not engage well more than most of my Kohlers. I have to take off the front motor tin to place graphite on the Bendix. Not an easy job! Share this post Link to post Share on other sites
ChrisHarkin 1 #9 Posted March 19, 2021 It’s a Kohler 8hp will have another look at the drive tomorrow Share this post Link to post Share on other sites
ChrisHarkin 1 #10 Posted March 19, 2021 22 minutes ago, Stormin said: My guess is the bearing/bush at the Bendix end of the motor badly worn. I've just replace that bush on three motors. Share this post Link to post Share on other sites
ChrisHarkin 1 #11 Posted March 19, 2021 I have stripped the starter motor and the bushes seemed ok Share this post Link to post Share on other sites
Achto 29,850 #12 Posted March 19, 2021 (edited) 13 minutes ago, ChrisHarkin said: I have stripped the starter motor and the bushes seemed ok Here is a link to one source for a starter drive, should you need one. http://www.psep.biz/store/kohler_starter_parts.htm Edited March 19, 2021 by Achto 1 Share this post Link to post Share on other sites
ChrisHarkin 1 #13 Posted March 20, 2021 (edited) 18 hours ago, pullstart said: Is there a way you could upload a video of the noise and action to YouTube and share it here? I’ve put in on YouTube under “ Noisy starter motor on a Kholer K181” Thanks Edited March 20, 2021 by ChrisHarkin Share this post Link to post Share on other sites
ChrisHarkin 1 #14 Posted March 20, 2021 I’ve put in on YouTube under “ Noisy starter motor on a Kholer K181” Thanks Share this post Link to post Share on other sites
Pullstart 68,181 #15 Posted March 20, 2021 2 hours ago, ChrisHarkin said: I’ve put in on YouTube under “ Noisy starter motor on a Kholer K181” Thanks Share this post Link to post Share on other sites
Pullstart 68,181 #16 Posted March 20, 2021 Looking at the flywheel as the key is turned, it sounds like the starter (brushes or armature?) are dirty or weak or worn. Side note, that sure is a nice paint job! Share this post Link to post Share on other sites
ChrisHarkin 1 #17 Posted March 20, 2021 6 hours ago, pullstart said: Share this post Link to post Share on other sites
ChrisHarkin 1 #18 Posted March 20, 2021 (edited) 5 minutes ago, ChrisHarkin said: Actually a bit embarrassing I took the engine cover off and watched the starter motor in action and straight away realised I had put the coil bracket on behind the motor instead of in front. Turned it around and starter worked perfectly. what threw me was the starter motor bracket had recesses which looked like they would take the fixing bolts ! Thanks to everyone for their help and assistance. Still learning !! Thanks for the compliment on the paintwork. Edited March 20, 2021 by ChrisHarkin Share this post Link to post Share on other sites
seuadr 489 #19 Posted March 20, 2021 53 minutes ago, ChrisHarkin said: Actually a bit embarrassing I took the engine cover off and watched the starter motor in action and straight away realised I had put the coil bracket on behind the motor instead of in front. Turned it around and starter worked perfectly. what threw me was the starter motor bracket had recesses which looked like they would take the fixing bolts ! Thanks to everyone for their help and assistance. Still learning !! Thanks for the compliment on the paintwork. that'll do it! we are all learning something every day, being willing to admit you made a mistake not only shows your character, but also helps someone else who might run into the same issue - so good on ye! 1 Share this post Link to post Share on other sites
