TJ5208 1,841 #1 Posted March 17, 2021 can i ask how to tune a 8 hp briggs engine nephew poured gas in the intake floated the bobber not sure what to do drained it by taking the fuel control or whatever it is called Share this post Link to post Share on other sites
Achto 29,838 #3 Posted March 17, 2021 28 minutes ago, Tj salyers said: can i ask how to tune a 8 hp briggs engine nephew poured gas in the intake floated the bobber You need to keep your nephew away from your tractor. First pull the spark plug out and turn the engine over several times to clear the gas from the cylinder. Then check the oil, make sure that it is not over full from gas draining in the crank case. If it is over full or smells like gas then change the oil. After those checks, put the spark plug back in and you should be good to go. 4 1 Share this post Link to post Share on other sites
953 nut 62,173 #4 Posted March 17, 2021 10 hours ago, Achto said: Then check the oil, make sure that it is not over full from gas draining in the crank case. If it is over full or smells like gas then change the oil. I think an oil change is in order even if only a drop of oil made it by the rings. Cheaper than an engine rebuild. 3 Share this post Link to post Share on other sites
TJ5208 1,841 #5 Posted March 17, 2021 He runs just not right give him throttle I start choking up Idle still won't run is it because of a govener spring don't know were to put it Share this post Link to post Share on other sites
