chev0545 237 #1 Posted March 11, 2021 when you go to put in gear the motor shuts off. thanks Share this post Link to post Share on other sites
953 nut 64,651 #2 Posted March 11, 2021 Is your PTO lever pulled back toward you? Share this post Link to post Share on other sites
The Tuul Crib 7,353 #4 Posted March 11, 2021 Seat switch? 1 Share this post Link to post Share on other sites
Handy Don 16,062 #5 Posted March 11, 2021 Gotta be a short or open circuit somewhere. Losing power to the coil: A wire grounding out (or being disconnected) when the clutch is depressed or the shift lever is moved? Follow the wire(s) from the "+" terminal on the coil back toward the ignition switch. One of them is being grounded or broken or a connection is failing. Losing a good ground: Follow the wires from the negative terminal of the battery and make sure they are well-connected. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,067 #6 Posted March 11, 2021 Two neutral relays on this model 2 1 Share this post Link to post Share on other sites
grinchsr 657 #7 Posted March 12, 2021 With that model if your parking brake is on and you try to put in gear it will shut down. I have the same machine 2 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #8 Posted March 12, 2021 1 hour ago, grinchsr said: With that model if your parking brake is on and you try to put in gear it will shut down. I have the same machine I know this is a gear drive version, but they have the same safety/interlocks on the Hydro version, not only that if the shifter/motion control is in anything other than "nuetral" and got off the seat it will shut down a well, there's another thread asking how to stop/shut down and older tractor with it running, if getting off and accidentally bumping the shifter lever. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,067 #9 Posted March 12, 2021 Added the ignition switch to the colored wiring diagram above and refined it a bit. There is also a service bulletin that may apply to the problem. Garry 1 Share this post Link to post Share on other sites
