TJ5208
Gauges
TJ5208
Has anybody have a oil pressure gauge or gauges on there with horses I thought about trying that on the Raider 10 when I can get it like the RPM gauge and pressure gauge and the voltmeter gauge and while the rest of the gauges
pfrederi
Raider 10 is a splash lubricated engine.  no oil pump no pressure...
TJ5208
Okay
TJ5208
 any other gauges work
Stepney
I guess you could add a voltage, hour, or ammeter gauge. Not much you can really add to that machine. They never originally had anything at all. Didn't much need it, the engine was self sufficient with it's magneto once started. If it didn't start, clearly either the battery was dead, or the alternator had failed.
K.I.S.S. goes a long ways on these older models.
meadowfield
My C-121 is all gauged out :D
ranger
Wow! Mark,  that’s certainly a low hours tractor.
  • Haha 1
meadowfield
hahaha, high hours, but never had an hour counter!  turns out this hour counter - was boxed wrong - it's a mains one, so this has failed to clock an hours use :(
  • Sad 1
TJ5208
Nice gauges how did you do it
TJ5208
What gauges did you get maybe links
Handy Don
So is that fuel gauge US or Imperial units? :)
meadowfield
Neither, I fill in the UK so it it's litres - about 11 and a bit litres to be precise :D
meadowfield
just cheap chinese ones
TJ5208
do you know were you got them from
meadowfield
just on that auction site, sometimes sold in packs of three. They are really basic, but not to hard to wire up. The rev counter needed modifcation as that will not work on a single - theres a thread on that from about 7 years ago.
TJ5208
ill try to find it
meadowfield
Doug.... look!!!  I put a 12V hour meter on, I’ve done an hour of snow clearing since...
Edited by meadowfield
