chev0545 237 #1 Posted March 5, 2021 at times from going from forward to reverse or visa versa it blows the 30 amp fuse.any thoughts thanks Share this post Link to post Share on other sites
rmaynard 16,992 #2 Posted March 5, 2021 I would check to see if you are pinching or rubbing against a wire with the linkage. The seat switch wires hang down in the area of the cam, but I'm not sure if they are in a 30 amp circuit. 1 Share this post Link to post Share on other sites
rmaynard 16,992 #3 Posted March 5, 2021 What year is the 416-H? 1 Share this post Link to post Share on other sites
rmaynard 16,992 #4 Posted March 5, 2021 The following info is based on the 1992 - 1997 416's The only circuits where a 30A fuse is supposed to be is the charging circuit. and the starter solenoid circuit. I would be looking for something shorting out in that wiring. 1 Share this post Link to post Share on other sites
chev0545 237 #5 Posted March 5, 2021 33 minutes ago, rmaynard said: What year is the 416-H? 97 Share this post Link to post Share on other sites
rmaynard 16,992 #6 Posted March 5, 2021 15 minutes ago, chev0545 said: 97 Thanks. I refer you to the two circuits shown above. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,069 #7 Posted March 5, 2021 1 Share this post Link to post Share on other sites
