pfrederi 21,146 #1 Posted March 5, 2021 Throttle cable clamp used on big block K Singles at the end of the cable. Kohler # 4875510. Still available for only $15.83 each... I figure that they must not be that uncommon and probably available a lot cheaper from McMaster Fastnal etc...IF I knew what another name would be... Any ideas?? Share this post Link to post Share on other sites
Maxwell-8 4,371 #2 Posted March 5, 2021 Not the best solution but i use an electric lego clamp 1 1 Share this post Link to post Share on other sites
rmaynard 17,582 #3 Posted March 5, 2021 It's called an adjustable cable clamp. 2 Share this post Link to post Share on other sites
stevasaurus 23,855 #4 Posted March 5, 2021 Looks like it would be easy to make on a lathe. I google image...adjustable cable clamp. 1 Share this post Link to post Share on other sites
littleredrider 409 #5 Posted March 5, 2021 should be able to get them a decent hardware store. Used them on go carts back in the day.... 4 Share this post Link to post Share on other sites
pfrederi 21,146 #6 Posted March 5, 2021 18 minutes ago, stevasaurus said: Looks like it would be easy to make on a lathe. I google image...adjustable cable clamp. Great idea all I have to do is buy a $2,000 metal lathe (and learn hour to use it) 2 7 Share this post Link to post Share on other sites
ranger 1,862 #7 Posted March 5, 2021 Over here (UK) it’s called a “ solder less nipple”. 1 1 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #8 Posted March 5, 2021 One of the reasons I try to keep a couple Wheel Horses in the bone yard! Worth their cost after a few parts. And by golly I learn something everyday. Got to thinking about it and now I understand why. Many ends are cast in solder! “ solderless nipple” 3 Share this post Link to post Share on other sites
bc.gold 3,406 #9 Posted March 5, 2021 Carburetor cable attachment swivel throttle choke 2 Share this post Link to post Share on other sites
Mickwhitt 5,259 #10 Posted March 5, 2021 Yep definitely a solderless cable nipple. Only need a small lathe really, in fact I could make one of these with a drill press. Mick 4 1 Share this post Link to post Share on other sites
squonk 48,108 #11 Posted March 5, 2021 1 hour ago, pfrederi said: Throttle cable clamp used on big block K Singles at the end of the cable. Kohler # 4875510. Still available for only $15.83 each... I figure that they must not be that uncommon and probably available a lot cheaper from McMaster Fastnal etc...IF I knew what another name would be... Any ideas?? It's not snowing and it's 3 1/2 months to the show. You have time to go thru the entire MMC Catalog! 4 Share this post Link to post Share on other sites
Mickwhitt 5,259 #12 Posted March 5, 2021 I will make one tomorrow, see how long it takes. Doesn't need the hexagonal section, just a rim to hold it in the throttle arm. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #13 Posted March 5, 2021 Throttle cable clamp Share this post Link to post Share on other sites
roadapples 6,987 #14 Posted March 5, 2021 I saw those recently, but not sure where. Maybe Lowes, TSC, ACE hardware??? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #15 Posted March 6, 2021 4 hours ago, pfrederi said: Throttle cable clamp used on big block K Singles at the end of the cable. Kohler # 4875510. Still available for only $15.83 each... I figure that they must not be that uncommon and probably available a lot cheaper from McMaster Fastnal etc...IF I knew what another name would be... Any ideas?? https://www.jackssmallengines.com/jacks-parts-lookup/part/azusa/2361?gclid=cj0kcqiayoecbhctarisaofpkxhfpvbqfhgfk2p948gy9i9ltfe-ngyzmueyxjqadjbgklx34ueb6mcaajbhealw_wcb 2 1 Share this post Link to post Share on other sites
pfrederi 21,146 #16 Posted March 6, 2021 OK thank you all Good price at same place I get my Posiflo fuel pumps... Azusa 2361 Wire Swivels 3 Share this post Link to post Share on other sites
ranger 1,862 #17 Posted March 6, 2021 (edited) In the dim and distant past, I’ve made new nipples for throttle/clutch/brake cables on my old motorcycles by trimming a small amount off the outer cable, splaying the end of the inner cable strands outwards, drilling the size of hole needed for the nipple in a piece of hardwood, cutting a slot in the wood up to the hole, then laying the inner cable in the slot with the “splayed” end in the hole. After melting some solder or lead, pouring it into the hole, you then have a new end to your cable. The splayed strands prevent the nipple pulling off the cable. p.s. Sometimes there’s not enough room in the throttle lever/twist grip to fit a solderless nipple. I seem to remember the heavy duty cables had brass nipples with a small countersink where the cable end was splayed into then soldered Edited March 6, 2021 by ranger Share this post Link to post Share on other sites
oliver2-44 11,739 #18 Posted March 6, 2021 My Ace hardware has them in the Hillman gray drawers. 4 1 Share this post Link to post Share on other sites
peter lena 10,061 #19 Posted March 6, 2021 know i have seen them at my local , ACE H/W STORE, in the small pullout drawer section , regularly cruise thru that area for a look see, pete 2 Share this post Link to post Share on other sites
KAA 1973 71 #20 Posted March 6, 2021 They are pretty cheap at go kart supply vendors https://www.gokartsupply.com/thcable.htm BMI Karts is usually my go to place https://www.bmikarts.com/Racing-Go-Kart-Throttle-Cables-and-Parts 1 1 Share this post Link to post Share on other sites
peter lena 10,061 #21 Posted March 6, 2021 KAA 1973, that's the kind of answer , we want , with a direct picture / name reference point. all too often we are looking for something just to get us going on an issue . don't hesitate to look around for another source, pete 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #22 Posted March 6, 2021 36 minutes ago, peter lena said: KAA 1973, that's the kind of answer , we want , with a direct picture / name reference point. all too often we are looking for something just to get us going on an issue . don't hesitate to look around for another source, pete Refer to post 15 too. Share this post Link to post Share on other sites
Gregor 4,848 #23 Posted March 7, 2021 (edited) Sex bolt/nut with a hole drilled in it works for me. Found at most hardware stores Edited March 7, 2021 by Gregor Share this post Link to post Share on other sites
DennisThornton 4,773 #24 Posted March 7, 2021 1 hour ago, Gregor said: Sex bolt/nut with a hole drilled in it works for me. Found at most hardware stores I managed a hardware store and had NO idea what you were referring to, saw the picture and Googled. We called those "Chicago Screws" but they didn't have the nurl. 69 and I think I still learn something here about everyday. "Sex bolts"! I'll be darned! Share this post Link to post Share on other sites
Mickwhitt 5,259 #25 Posted March 7, 2021 "Sex bolt sex bolt, I'm a sex bolt" Lol, I've used em plenty of times and never come across that name. Imagine walking into a hardware store and asking for a box of sex bolts. ... make four candles look tame. Share this post Link to post Share on other sites
