t.stevens 0 #1 Posted March 4, 2021 Having trouble starting my Wheel Horse. Plenty of spark, fuel doesn't seem to be the issue. See Video link for sound. Any advice helps, thanks. https://photos.google.com/share/AF1QipOa-YcF05_9qAS10y-tH2qgdAaG4myjbY0A-V63MAm4K-7_n_R1v0QdrmoYn9WP_A?key=M1VSVmkyQUM5bndoeDFHVFdWOHdLUDMzVG5oZWlB Share this post Link to post Share on other sites
Achto 31,019 #2 Posted March 4, 2021 49 minutes ago, t.stevens said: Having trouble starting my Wheel Horse. Plenty of spark, fuel doesn't seem to be the issue. Sorry, I can't always get video's to show on my work computer. I.T. locks us out. What make/model engine do you have? Is it battery ignition or magneto? If you have good spark and good gas. The only 2 things left are compression and timing. 2 Share this post Link to post Share on other sites
Jeff-C175 7,207 #3 Posted March 4, 2021 You're gonna burn out that starter like that. 58 minutes ago, t.stevens said: trouble starting my Wheel Horse Try this Achto, might work. I think the other link isn't inserted correctly. https://photos.google.com/share/AF1QipOa-YcF05_9qAS10y-tH2qgdAaG4myjbY0A-V63MAm4K-7_n_R1v0QdrmoYn9WP_A/photo/AF1QipNSwWRrjzZkZ3KGWAks-n51B9kqmGIchBqT96yJ?key=M1VSVmkyQUM5bndoeDFHVFdWOHdLUDMzVG5oZWlB 2 Share this post Link to post Share on other sites
t.stevens 0 #4 Posted March 4, 2021 13 minutes ago, Achto said: Sorry, I can't always get video's to show on my work computer. I.T. locks us out. What make/model engine do you have? Is it battery ignition or magneto? If you have good spark and good gas. The only 2 things left are compression and timing. I believe it is battery started. Sorry I may have posted the link incorrectly. The engine is a Briggs and Stratton 11hp IC Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted March 4, 2021 Just now, t.stevens said: Briggs and Stratton I don't have any like that, but I wonder if it's 'normal' that the starter motor wiggles around like that. It didn't sound like there was much, if any, compression to me. Were there any unusual sounds come from the engine when it quit? The reason I mentioned burning out the starter is because you shouldn't really crank for more than a few seconds, and then the starter should be allowed to cool off. 2 Share this post Link to post Share on other sites
Achto 31,019 #6 Posted March 4, 2021 (edited) 6 minutes ago, t.stevens said: The engine is a Briggs and Stratton 11hp IC Nope this is the info I needed. With a Briggs, if you have fuel, spark and compression but it won't start. Then most of the time these symptoms lead toward the flywheel key being sheared. When this happens it will throw the timing off. Your engine will be a magneto ignition. Edited March 4, 2021 by Achto 3 1 Share this post Link to post Share on other sites
squonk 45,539 #7 Posted March 4, 2021 Sounds like the starter gear is about to take a dump too! 4 Share this post Link to post Share on other sites
Renrag 69 #8 Posted March 9, 2021 Don't sound as there's any resistance on the starter at all 1 Share this post Link to post Share on other sites
