ebinmaine 78,645 #26 Posted March 4, 2021 Just now, krystolo said: Yeah, that’s a good point. 🤔 You could solve this great issue by getting another Wheelhorse. One to hold the trailer. One to push muck. 1 Share this post Link to post Share on other sites
krystolo 504 #27 Posted March 4, 2021 1 minute ago, ebinmaine said: You could solve this great issue by getting another Wheelhorse. One to hold the trailer. One to push muck. Wouldn't the first one get jealous? 1 Share this post Link to post Share on other sites
ebinmaine 78,645 #28 Posted March 4, 2021 Just now, krystolo said: Wouldn't the first one get jealous? Oh no no no no no They're a herd animal like a hair covered horse. They LOVE companions!!! 1 Share this post Link to post Share on other sites
krystolo 504 #29 Posted March 4, 2021 What about a winch/hoist mounted to the back of the tractor? Kind of like Eric's dump cart. Doable? Gotta be careful not to get my hair caught in it. 😂😂😂 1 Share this post Link to post Share on other sites
krystolo 504 #30 Posted March 4, 2021 8 minutes ago, ebinmaine said: Oh no no no no no They're a herd animal like a hair covered horse. They LOVE companions!!! I’m going to have two red horses! One of my horses’ names is Red! 2 Share this post Link to post Share on other sites
ebinmaine 78,645 #31 Posted March 4, 2021 19 minutes ago, krystolo said: I’m going to have two red horses! One of my horses’ names is Red! That's just awesome. Share this post Link to post Share on other sites
ebinmaine 78,645 #32 Posted March 4, 2021 20 minutes ago, krystolo said: What about a winch/hoist mounted to the back of the tractor? Kind of like Eric's dump cart. Doable? Gotta be careful not to get my hair caught in it. 😂😂😂 Absolutely doable. There are winch mounts available for trailer hitches. That would also give you the capabilities of lifting/moving things other than the trailer. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #33 Posted March 4, 2021 34 minutes ago, krystolo said: Cool design! I have similar in a newer plastic version, but neither will dump cleanly and require a dump, forward movement and then some elbow with shovel movement to fully clear the cart. OR! Block the wheels and backup a bit to completely raise the wheels and entire cart up. Works better than a wheelbarrow but still lacking somewhat. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #34 Posted March 4, 2021 36 minutes ago, krystolo said: Wouldn't the first one get jealous? No! They work very well together! So much so that others will appear in time! Share this post Link to post Share on other sites
DennisThornton 4,773 #35 Posted March 4, 2021 28 minutes ago, krystolo said: What about a winch/hoist mounted to the back of the tractor? Kind of like Eric's dump cart. Doable? Gotta be careful not to get my hair caught in it. 😂😂😂 Absolutely! Even a hand crank boat winch! Share this post Link to post Share on other sites
DennisThornton 4,773 #36 Posted March 4, 2021 29 minutes ago, krystolo said: I’m going to have two red horses! One of my horses’ names is Red! You bought a whole LOT of horsepower for not much money! Now it's up to you! Share this post Link to post Share on other sites
ebinmaine 78,645 #37 Posted March 4, 2021 10 minutes ago, DennisThornton said: Absolutely! Even a hand crank boat winch! That's EXACTLY what mine is Share this post Link to post Share on other sites
DennisThornton 4,773 #38 Posted March 4, 2021 10 minutes ago, ebinmaine said: That's EXACTLY what mine is Yeah. I mean really. Why buy a 12v winch, run battery cables and switch when you can crank for a few seconds? 1 Share this post Link to post Share on other sites
ebinmaine 78,645 #39 Posted March 4, 2021 3 minutes ago, DennisThornton said: Yeah. I mean really. Why buy a 12v winch, run battery cables and switch when you can crank for a few seconds? You see my video above? The only thing I'd do different is use a flat strap instead of a cable. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #40 Posted March 4, 2021 2 minutes ago, ebinmaine said: You see my video above? The only thing I'd do different is use a flat strap instead of a cable. Yep. I have a Sears with a rear manual hoist for lifting and dragging. Works great! For it to work I have to get out of my seat anyway, what is a few second to crank whille I look at my load? For moving and dumping a LOT of material it's nice to stay seated and go back for more. I needed to move a small hillside and fill in a hollow so I used the CUT FEL and back box blade. On the move I'd load the FEL, then drop the box blade and fill it, drive to the dump site, dump the FEL, drive over it while raising the box blade and repeat. Moved a LOT of material quickly but does every GT owner expect to do that? I think most are just trying to get a notch above a wheelbarrow! Not move a hillside! Man! I spent way too much time with a shovel and wheelbarrow! (Still use them but not often and I don't admit it!) 1 Share this post Link to post Share on other sites
953 nut 65,826 #41 Posted March 5, 2021 When this question was asked I thought you were wanting to put in a ramp the cart could be pulled up next to. Share this post Link to post Share on other sites
krystolo 504 #42 Posted March 5, 2021 1 hour ago, ebinmaine said: You see my video above? The only thing I'd do different is use a flat strap instead of a cable. Yes! That looks perfect! could the boom be attached to the tractor near the hitch? 1 Share this post Link to post Share on other sites
krystolo 504 #43 Posted March 5, 2021 (edited) 13 minutes ago, 953 nut said: When this question was asked I thought you were wanting to put in a ramp the cart could be pulled up next to. Oh yes! That was one idea! Then someone mentioned using a piece of plywood. Push on, push off. Than I thought of plywood with sides to hold more, then sled runners for less resistance, then a dumpable sled. Lol gears were turning! awesome drawing! what materials would you suggest? Would need to be wood. Edited March 5, 2021 by krystolo Share this post Link to post Share on other sites
krystolo 504 #44 Posted March 5, 2021 1 hour ago, DennisThornton said: Yeah. I mean really. Why buy a 12v winch, run battery cables and switch when you can crank for a few seconds? The tractor has a four pin connector wired near the hitch. Thought I could plug the winch in there! I like to keep my butt in the saddle! 😂 1 Share this post Link to post Share on other sites
ebinmaine 78,645 #45 Posted March 5, 2021 18 minutes ago, krystolo said: Yes! That looks perfect! could the boom be attached to the tractor near the hitch? Certainly. Just a matter of fabricating a proper mount. 14 minutes ago, krystolo said: tractor has a four pin connector wired near the hitch. Thought I could plug the winch in there This can be done IIFF you wire the winch through a relay. The little wires feed the relay. The relay's heavy wire side feeds the winch. Share this post Link to post Share on other sites
DennisThornton 4,773 #46 Posted March 5, 2021 58 minutes ago, 953 nut said: When this question was asked I thought you were wanting to put in a ramp the cart could be pulled up next to. I think that is the best approach if possible to place the ramp! Share this post Link to post Share on other sites
haydendavid380 759 #47 Posted March 6, 2021 On 3/3/2021 at 7:28 PM, krystolo said: Wish I had a wife... I need someone to do my laundry, too. I went with the all-in-one model. Works as a dishwasher and runs the vacuum too. 1 Share this post Link to post Share on other sites
