ebinmaine 80,638 #1 Posted March 3, 2021 I've seen a few High Crops of various brands over the years but they're not super common in my realm. I understand what they're for. I also understand that by general nature something that is taller than standard such as these would be inherently less stable but where do you draw the line? How much taller are they than standard? I assume that varies based on maker or desired use? If you have a farm tractor that is five or six feet wide or whatever and you are increasing the height 6 or 10" is there any sort of noticeable decrease in stability? Whatever experiences or impressions you could share would be appreciated. Share this post Link to post Share on other sites
Pullstart 71,212 #2 Posted March 3, 2021 EB I’m no farmer or scientist or engineer, but I imagine a high crop is built so heavy and stout, the extra height is negligible at reasonable work speeds. They also look like an old gasser, so they must be awesome! 3 Share this post Link to post Share on other sites
seuadr 490 #3 Posted March 3, 2021 44 minutes ago, pullstart said: EB I’m no farmer or scientist or engineer, but I imagine a high crop is built so heavy and stout, the extra height is negligible at reasonable work speeds. They also look like an old gasser, so they must be awesome! this has been my limited experience. for instance, i have an oliver 550 - which is a compact tractor before there were compact tractors as a category, it is similar in size to my buddy's John Deere 1010 Row Crop - my tractor is a little bigger than his, and built STOUT and comes in at 3700 pounds (these are similar in size to like a for N series) his tractor comes in at 4200 pounds, and he doesn't actually have the row crop accoutrements attached, nor wheel weights/fluid in the tires, etc. 2 Share this post Link to post Share on other sites
953 nut 69,147 #4 Posted March 3, 2021 High Crop tractors were used for cultivation and were primarily used by flatlanders so stability wasn't that big of a concern. As a kid I cultivated corn and potatoes with a 1949 Case SC much like the one pictured below. The taller rear wheels and narrow front made it less stable than a high crop would probably be but we had no problem. 4 1 Share this post Link to post Share on other sites
Achto 32,633 #5 Posted March 3, 2021 (edited) As stated, high crops were generally used on flat land. Just like the row crops with a narrow front end, high crops could be very dangerous when used on the side of a hill. I knew people who were killed when their narrow front tractor tipped over sideways on them when they were using it on the side of a hill. Most high crop tractors were nothing more than a row crop jacked up in the air so they don't really weigh much more than the row crop does. You will seldom see a high crop with a narrow front end as these extremely dangerous. In short, YES you had to be careful with a high crop. Rolling them on their side was always a present danger. Edited March 3, 2021 by Achto 3 1 Share this post Link to post Share on other sites
WHX?? 58,068 #7 Posted March 3, 2021 We see ones like this barreling down the road quite frequently and they do have a road gear. 7 Share this post Link to post Share on other sites
DennisThornton 4,773 #8 Posted March 3, 2021 Similar down the road from me: 5 Share this post Link to post Share on other sites
JCM 11,415 #9 Posted March 3, 2021 This Super A is sort of row cropish, very stable especially when you adjust the axle width. 7 2 Share this post Link to post Share on other sites
squonk 48,072 #10 Posted March 3, 2021 48 minutes ago, WHX24 said: We see ones like this barreling down the road quite frequently and they do have a road gear. My house is about 15 ft off a main route but in the village. If one travels north there is a rt turn about 50 yrds. further down the road. The Mennonites drive these things blasting by my house and somehow make the corner. It's like being invaded by aliens! 3 Share this post Link to post Share on other sites
ebinmaine 80,638 #11 Posted March 3, 2021 14 minutes ago, JCM said: This Super A is sort of row cropish, very stable especially when you adjust the axle width. Love that tractor Jim. If it had a front end loader Trina would have already bought it but if I come up with even half an excuse you and I are going to have to talk!! 2 1 Share this post Link to post Share on other sites
Achto 32,633 #12 Posted March 3, 2021 (edited) 47 minutes ago, JCM said: This Super A is sort of row cropish All of the letter series Farmall's (A,B,C,H,M and the Cub) were considered row crop tractors. They had adjustable widths and more ground clearance and were labeled Farmall. The high crop versions of the Farmall's would have the letter V after the first letter. Like this MV for example. During that time the W series (W4,W6,W9,) were considered standard tractors. The W4 had the same engine as the H. The W6 had the same engine as the M. The W9 stood alone and had the largest engine for IH at the time. These were mainly tillage tractors, they did not have adjustable widths and were labeled as McCormick's. Edited March 3, 2021 by Achto 4 3 1 Share this post Link to post Share on other sites
WHX?? 58,068 #13 Posted March 3, 2021 I like that tractor Plunger didn't you do a resto thread on it? Share this post Link to post Share on other sites
JCM 11,415 #14 Posted March 3, 2021 No thread on that one Jimbo. 1 Share this post Link to post Share on other sites
Pullstart 71,212 #15 Posted March 3, 2021 3 hours ago, WHX24 said: We see ones like this barreling down the road quite frequently and they do have a road gear. I’ve been very tempted while riding motorcycle to cruise under one of those! I am pretty sure I’d fit, but not looking forward to being the splat on the bottom side of one! 3 Share this post Link to post Share on other sites
Achto 32,633 #16 Posted March 3, 2021 15 minutes ago, pullstart said: I’ve been very tempted while riding motorcycle to cruise under one of those! Had that very thought myself. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #17 Posted March 3, 2021 If you owned a tree farm then you would want one of these. 1 1 1 Share this post Link to post Share on other sites
8ntruck 9,289 #18 Posted March 3, 2021 2 hours ago, pullstart said: I’ve been very tempted while riding motorcycle to cruise under one of those! I am pretty sure I’d fit, but not looking forward to being the splat on the bottom side of one! Yup. I've had the thought when seeing one of these on the road that I could have passed it with the Trimuph Spitfire I used to have without having to go into the oncoming traffic lane. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,638 #19 Posted March 3, 2021 Bandit would be proud of you boys 1 Share this post Link to post Share on other sites
Zeek 2,299 #20 Posted March 3, 2021 (edited) I think John Deere started making Hi-Crops in 1955 with the JD 60 that replaced the A in 1952. They made it for corn, flowers and sugar cane crops. It was 32" clearance. It looked pretty beefy to me, I doubt stability would be an issue, although I have never driven one. Edited March 3, 2021 by Zeek 4 Share this post Link to post Share on other sites
8ntruck 9,289 #21 Posted March 4, 2021 Interesting, the tractor in the front view has braces betwen the lower end of the spindles, while the tractor in the side view does not. 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,936 #22 Posted March 4, 2021 Right now, if you watch Mecum's Gone Farming auctions, original from the factory Hi-Crops bring good money now, more than the standard row crop tractors. So much so that people are now modifying standard row crops to hi-crops. These don't bring as much money at the auctions from what I've seen, but they do get some attention. 1 Share this post Link to post Share on other sites
seuadr 490 #23 Posted March 4, 2021 6 hours ago, T-Mo said: Right now, if you watch Mecum's Gone Farming auctions, original from the factory Hi-Crops bring good money now, more than the standard row crop tractors. So much so that people are now modifying standard row crops to hi-crops. These don't bring as much money at the auctions from what I've seen, but they do get some attention. Yeah my buddy picked his up for 2k, not knowing it was special (nor the guy selling it) and sent it to a shop to get some clutch work done - the owner gave him a list of 5 people that wanted to buy it just as it was split on the shop floor. One guy offered 6k as is where is. My buddy was flabbergasted. He kept it though, he really likes it. It is a cool little machine. 2 Share this post Link to post Share on other sites
ebinmaine 80,638 #24 Posted March 4, 2021 What prompted the question in the first place is that I've been thinking about giving Colossus a little bit of the high crop treatment.. I think it'll be a really neat look for that. 6" wider rear, maybe a little more in the front. I think 16" longer? And the height increase will be maybe 4 rear, 6 or 7 front? Seems to me with these dimensions and the fact that I have four weighted tires it should still remain quite stable. 2 Share this post Link to post Share on other sites
Zeek 2,299 #25 Posted March 4, 2021 (edited) Here's one that used to be at the WHCC Show now and then. I don't recall who owned it, but I think the brothers had a few modified tractors like an articulated and narrow front. This was from 2013. The articulated one is in the background. I found two more on the interweb . . . Edited March 4, 2021 by Zeek 2 2 Share this post Link to post Share on other sites
