saminmn 17 #1 Posted March 2, 2021 I have a 341s thats .20 over. The book said its 3 3/4 " sized cylinder ,will a 3 3/4" ball hone work or what size should I buy? Share this post Link to post Share on other sites
Achto 30,210 #2 Posted March 2, 2021 2 hours ago, saminmn said: The book said its 3 3/4 " sized cylinder ,will a 3 3/4" ball hone work or what size should I buy? 3 3/4" hone will work just fine. They are usually a little over sized. 1 Share this post Link to post Share on other sites
richmondred01 2,319 #3 Posted March 3, 2021 Mic the cylinder first. Find out exactly what you have. Simply honing and new rings won’t fix a worn cylinder. Share this post Link to post Share on other sites
lynnmor 8,266 #4 Posted March 3, 2021 1 hour ago, richmondred01 said: Mic the cylinder first. Find out exactly what you have. Simply honing and new rings won’t fix a worn cylinder. Agree with that, also a ball hone will do nothing to straighten a bore where a three stone type will help a bit. Only a rigid hone or bore job will do a proper repair of an out of spec. cylinder. Share this post Link to post Share on other sites
pacer 3,177 #5 Posted March 3, 2021 I like both types ... A "dingleberry" (ball type) is my most often choice, but I like to have a good condition 3 stone for the occasional cylinder. Oddly enough, I am right now working on a recent K532 that ran really well but needed to strip all the tin off to get rid of a LOAD 0f chaff. So, when I'm this far into a new - to me - engine I will at least pull the heads to get an idea of its internal condition. So for the first time in the some 30-40 engines I have been into - this one was absolutely pristine, cyls checked exactly on standard specs and on pulling a valve to ck its condition it also was like a new one!! I must have miced those cyls 3-4 times thinking they couldnt be THAT dead on! I didnt even break out either hone -- did a slight adjust on one intake and one exhaust valves clearance and am putting it back together. I wish they could all be that way! Share this post Link to post Share on other sites
