Shuboxlover 483 #1 Posted February 20, 2021 Does anyone know if a hydro pump from a 520-H would fit in a 520xi? Thanks Share this post Link to post Share on other sites
Handy Don 14,951 #2 Posted February 20, 2021 I sure don't know Share this post Link to post Share on other sites
JoeM 9,098 #3 Posted February 21, 2021 (edited) Yes....but the charge pump inlet is different on the xi. The 520 uses a steel tube fitting and the xi uses a hose fitting. To change the fitting the charge pump must be removed because the fitting will not turn hitting the pump if bolted in place. If you are not comfortable removing the charge pump, a steel tube from the 520 can be cut off just below the pump and the xi inlet hose pushed up on it and clamped. Also, got to use the xi bevel gear on the output shaft. Hope this helps. Edited February 21, 2021 by JoeM 1 Share this post Link to post Share on other sites
Shuboxlover 483 #4 Posted February 21, 2021 Thank you!!! 1 Share this post Link to post Share on other sites
