peter lena 9,782 #1 Posted February 20, 2021 just got this on line , just thought i would pass it on , https://www.amazon.com/Polaris-Blade-Wear-Bar-2871805/dp/B000M6T1G6/ref=pd_sbs_5?pd_rd_w=UTxHO&pf_rd_p=3ec6a47e-bf65-49f8-80f7-0d7c7c7ce2ca&pf_rd_r=PRNXBJS2YPG576BQYH99&pd_rd_r=914ba3af-da64-43d5-911c-222f0d437b7f&pd_rd_wg=XqehO&pd_rd_i=B000M6T1G6&psc=1 , a number of related plow type related fittings ,make up what you need for your issue, pete 2 Share this post Link to post Share on other sites
peter lena 9,782 #2 Posted February 20, 2021 just back in from plowing , ,when I plow or move snow , regularly move it to my advantage to work with the angle of the sun , rather than shade. shifting snow from a known shade side of the driveway , to the sun angle side , for most of the day , melts down and makes it easier to gain on " touch up plowing ". my driveway quickly turned asphalt black , as the sun melted off the thin remaining snow coating . obviously plowing my grass back yard areas , is a matter of getting what ever you can ,as soon as you can , pushing far out , to get ready for more. silicone blade rub down , makes snow move like magic , would like to plow snow all day , pete 2 Share this post Link to post Share on other sites
R. L. Addison 300 #3 Posted February 20, 2021 Yup, Yup, Yup, I totally concur with your analysis of the whole mess! 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #4 Posted February 20, 2021 32 minutes ago, peter lena said: just back in from plowing , ,when I plow or move snow , regularly move it to my advantage to work with the angle of the sun , rather than shade. shifting snow from a known shade side of the driveway , to the sun angle side , for most of the day , melts down and makes it easier to gain on " touch up plowing ". my driveway quickly turned asphalt black , as the sun melted off the thin remaining snow coating . obviously plowing my grass back yard areas , is a matter of getting what ever you can ,as soon as you can , pushing far out , to get ready for more. silicone blade rub down , makes snow move like magic , would like to plow snow all day , pete I've always tried to catch the sun to help with melting off what snow I leave. Sun even helps salt do it's job. And the sun does move through the trees and quickly shades the porch and front of the drive so I have to plan what I do with the sun. 3 Share this post Link to post Share on other sites
Ed Kennell 45,042 #5 Posted February 20, 2021 Unfortunately, my steep front driveway is facing due North and sees very little sun being shaded by the house. 1 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #6 Posted February 20, 2021 4 minutes ago, Ed Kennell said: Unfortunately, my steep front driveway is facing due North and sees very little sun being shaded by the house. On a sunny winter's afternoon I was visiting with a friend's neighbor with a very steep on long blacktop drive and I commented that it must be a nightmare in winter. He replied, "Nope!". I looked around and asked why? He asked me, "Where's the sun?". Due south! Lots of snow but none on the driveway! Now, there's times up here in December and January that the sun is pretty scarce, but it sure helps when it shows up! 4 Share this post Link to post Share on other sites
