Pullstart 68,883 #1 Posted February 17, 2021 I have this K662 Kohler twin. It is mostly propane. But many things are missing. I have found that a Model 28 Zenith carburetor might have been stock on that engine. Does that mean 28 mm Venturi? Could I essentially tune any 28mm carb to work? I was thinking maybe a horizontal flow carb like most of what we’re used to, then a 90 degree intake tube. I could fashion it in any reasonable direction for a filter. Share this post Link to post Share on other sites
Pullstart 68,883 #2 Posted February 17, 2021 The 662 is 1101 cc. Possibly I should search for a comparable size engine to see what reasonable carb I could find? Today a KT735 (735 cc) makes 24 hp, like this K662 did. Share this post Link to post Share on other sites
Achto 31,017 #3 Posted February 17, 2021 I have some Mikuni carbs from 16hp vanguards if you would be interested. They are vertical venturi. Not sure on the bore, I can look tonight. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,357 #4 Posted February 17, 2021 Get out your welder and some piping and make up a triple intake. Put three, 8 horse carburetors on there and call it fantastic. 2 2 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #5 Posted February 17, 2021 1 hour ago, pullstart said: The 662 is 1101 cc. Possibly I should search for a comparable size engine to see what reasonable carb I could find? Today a KT735 (735 cc) makes 24 hp, like this K662 did. 1000-1200cc Harley-Davidson carb... 1 1 Share this post Link to post Share on other sites
squonk 45,535 #6 Posted February 17, 2021 If you use the Harley carb, try to find one that hasn't fallen off the bike at highway speed. 1 2 Share this post Link to post Share on other sites
