spark949 24 #1 Posted February 14, 2021 I have a 77 C-160 that the starter has gone bad on. The motor is a K341S on the label serial number 7467510 . I see multiple starters listed but most say 1985-1987 10.12,14 HP which look like the same starter. If I look at the starters with the numbers listed fir that motor, they are not the same as the one I took off. anyone know the proper stater fir this motor? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,921 #2 Posted February 14, 2021 Does this spec number match what is on the engine? https://www.partstree.com/models/k341-71223-kohler-k-series-engine-made-for-wheel-horse-16hp-11-9kw/ Garry Found some dimensions here https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=5591 Share this post Link to post Share on other sites
ebinmaine 76,550 #3 Posted February 14, 2021 47 minutes ago, spark949 said: starter has gone bad Have you disassembled the existing starter to verify the issue? You may be better off rebuilding your own. Could be something simple like a worn bushing causing it to bind. Share this post Link to post Share on other sites
roadapples 6,985 #4 Posted February 14, 2021 Agree with Eric. May just need a good cleaning. Blow it out good with compressed air... 1 Share this post Link to post Share on other sites
spark949 24 #5 Posted February 14, 2021 Illl pull it apart and take a look. Thanks 1 Share this post Link to post Share on other sites
stevasaurus 23,534 #6 Posted February 14, 2021 This thread may help. This starter was on a 10 hp Kohler. It is called a "High Mount" starter. Yours may be very similar, and this thread helpful. 1 Share this post Link to post Share on other sites
squonk 45,083 #7 Posted February 14, 2021 I just replaced the starter on my 76 C-160. The engine is not original. It is an unknown year. I had to replace the starter on the original engine and got one off of a 74 C-160 parts tractor. It bolted right up and worked well. The replacement engine came with a starter so I took off the one I put on the original one and put it back on the shelf. Today I put that shelved starter back on and it fits perfect and starts nice. There was a sticker on the starter I installed: Johnson Electric 4509809 That is a Kohler number. Chances are the starter you were looking at will work fine. Share this post Link to post Share on other sites
spark949 24 #8 Posted February 15, 2021 Thanks for the info...nice write up on the starter clean out....I’ll update when I get a fix. Share this post Link to post Share on other sites
rmaynard 16,771 #9 Posted February 15, 2021 Back in 1996, I had to replace the starter on my B-100 (K-241). The dealer sold me a K-341 starter. He said that the fit was the same. Only difference was this starter had a 13 tooth gear vs. a 10 tooth gear. The 13 tooth would turn my engine over faster than the 10 tooth. If you need to replace your starter, there are many available on venues like Amazon or eBay for under $50.00. Just be sure to get a 13 tooth for your K-341. 1 Share this post Link to post Share on other sites
spark949 24 #10 Posted February 23, 2021 (edited) I bought one on Amazon.....of course it got lost. Had to order another one from a different supplier and that was “delayed “ somewhere out in the world. Finally came, 5 minute install, starts like a champ but it does sound like a 60s whiny dodge starter. The one I pulled out was completely fubar. Thanks for all the help. Edited February 24, 2021 by spark949 Share this post Link to post Share on other sites
