chev0545 237 #1 Posted February 14, 2021 on a 1995 314 magnum does the motor have to be running to register? thanks Share this post Link to post Share on other sites
Handy Don 15,773 #2 Posted February 14, 2021 If you have the wiring diagram, you can see if the meter is connected to the run or accessory terminal on the ignition switch directly or through the oil pressure switch (if there is one!). If the former, meter ticks whenever the ignition is on (running or not). If the latter, meter ticks only when engine is running (i.e. when there is oil pressure) 2 Share this post Link to post Share on other sites
troutbum70 858 #3 Posted February 14, 2021 On my 417's the hour meter runs when the switch is in the run position, running or not. 1 Share this post Link to post Share on other sites
Handy Don 15,773 #4 Posted February 14, 2021 The 14's don't have oil pumps, so there won't be a pressure sensor to wire through. So 1 Share this post Link to post Share on other sites
Lee1977 7,546 #5 Posted February 14, 2021 1 hour ago, chev0545 said: on a 1995 314 magnum does the motor have to be running to register? thanks No if the switch is left on it keeps running. 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #6 Posted February 14, 2021 On my 314, I only put the ignition on(not starting) and the hour meter was ticking, turned it back off and kept ticking for a couple of seconds. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #7 Posted February 14, 2021 Click on the picture to view the diagram 1 Share this post Link to post Share on other sites
Handy Don 15,773 #8 Posted February 14, 2021 6 hours ago, Maxwell-8 said: On my 314, I only put the ignition on(not starting) and the hour meter was ticking, turned it back off and kept ticking for a couple of seconds. The meters on the tractors I've touched (including one non-working meter I disassembled out of curiosity) had small electric motors. The disassembled one had a flywheel and miniature governor and the motor coasted for at least a few seconds after having the power cut off. It had failed because one of the electrical connections through the back of the housing broke off. 2 Share this post Link to post Share on other sites
