417Horse
Shoes for dozer blade
417Horse
What's the jungle site?
Horse Newbie
13 minutes ago, cschannuth said:
When I used a 520 to plow I used chain for the lift link.  BC319D75-2737-49B3-A271-14778FC598CF.jpeg.9740cb42933546121672ccf8fe814bf0.jpeg
We don't get much snow here in the Southern Piedmont of NC...
I still have a dozer/ snow blade for my 1994 520H.
I have thought about the "down pressure" bars I have seen on here to use with my blade.
And knowing me I will still aquire some...but for the amount of snow we rarely get, I think using the lift chain on my set up, relying on the weight of the blade will work fine.
Edited by Horse Newbie
Horse Newbie
Amazon online shopping
  • Thanks 1
417Horse
Gotcha, thanks
peter lena
417 horse, do you have a atv quad shop near by ? that is where I  picked up my polyurethane blade edge , perfect for a driveway damage issue , easily cut to match the size of your steel edge , https://www.amazon.com/FallLine-Polyurethane-Snow-Plow-Edge/dp/B00S5JRZAG   just using this for a reference point , but chances are a local atv /  quad shop will have them in stock , this is a very simple swap , also silicone spray your blade face , for easy snow sliding , pete
417Horse
Thanks, Pete
Pullstart
I can attest to the strength of a poly edge.  Many commercial snow plows run them including a 16’ swing wing I used to own and operate.  They last practically forever.  I also had a thought.  Can your lift lever limit the down travel?
417Horse
Pete, how thick is the blade material you purchased? I checked out the link you sent me. 3/4" would be too thick, I think.
peter lena
417, I think mine is close to that thickness, why would it be too thick? just get longer   carriage bolts , another thing  I also use washers and elastic lock nuts on back side. another thing is that you will probably get a longer than your size edge, with that cut off , you could make up some additional sliders , simple stuff, pete
417Horse
Pete, how tall is the piece you used? My blade is 48" wide, so the one on Amazon would be the correct length. I'd probably drill holes in the center so it could be flipped later down the road.
  • Excellent 1
cschannuth
Mine is 1/2” thick and 4 1/2” tall. I drill the holes in the middle and then flip it when it’s worn.
  • Like 3
417Horse
Do you remember where you got it from? Quad shop?
cschannuth
Fleabay
peter lena
417, mine was 54" wide, cut it down to 42 "  just used quad shop as a phrase, it was a motorcycle shop , that also sold ATV ,S  and related options , like plow blades , and poly edging blades for paved driveways. always looking for alternative ways to solve an issue . you might check locally at a cycle shop , on price and availability, might also notice other related goodies you can use, take the time to LUBRICATE YOUR PLOW STEERING QUADRANT AND RELATED LINKAGE , should swing with ease ,and lever pin should snap into quadrant hole arc with ease. silicone blade for snow release, pete
peter lena
417 horse, my blade was 54 "  wide / long , cut it down to my 42" blade size, pete
417Horse
Got iced in on top of snow and lost power for 8 hours yesterday so I was on generator detail - yeah, I keep a can of silicone spray handy to use on the blade surface and the pivot points - really makes a difference! CSC and Pete, I'm gonna check with local shops for the blade material come Monday so I'll be ready next time. Thanks, David
ebinmaine
I'd had something in the pivot quadrant. Maybe rust?
Lubed a few times over the past year.
The last storm it made a huge difference. I grabbed the pivot and the blade nearly flew from one side to the other.
moe1965
Ask around or call your local towns and townships and see if they use a rubber blade on there snowplows when they change them out there is  plenty of meat left for use on a tractor blade
Edited by moe1965
  • Like 3
417Horse
Thanks, Moe. I've made that my project this coming week. I've also got some friends in the plow business so I'm sure I can find something soon. Is that about 3/4" thickness in your pic?
moe1965
1 1/2 thick
  • Similar Content
    • rustyedge1
      By rustyedge1
      Going to need tie rods, one of mine came apart today. Was wondering if anyone could recommend someone ?
      Would settle for good used parts if available from someone. Dose anyone know the part numbers for my machine.
      Thanks in advance for the help.
      Dan
    • Elijah’s Wheel Horse 417A
      By Elijah’s Wheel Horse 417A
      Hello all, I recently inherited a Wheel Horse 417-A from my Late Grand-Father. It has been leaking from the Oil Pressure Sensor and I can’t seem to find this particular sensor anywhere If you could give me some leads that would be great! The engine is a KT17 Series II it smokes right under the muffler coming from the sensor i would like to fix it as it has the mowing deck, 2 Tillers, snow plow/dozer, snow blower, and 2 cabs this tractor is very centimental to me and it runs amazing other than this little part!! Also if you could provide any information on this particular model that would be great! Thanks!
    • The Gman
      By The Gman
      A short vid of my 312/417 in infrared. It's a FLIR one. Uses a smart phone, I have an old Note2. After looking at it I did notice the rear cylinder exhaust seemed to be running cooler. It will even show what wires are drawing more current and heating up
      Enjoy????
      flir_20180123T111311.mp4
    • 417Horse
      By 417Horse
      I have a 417-8 Horse that dropped a tie rod today.  The Wheel Horse parts manual calls for a #102592 for the RH rod and a #102593 for the LH rod. What is the newer (Toro) part #?  Also, from the pictures I've seen, the newer tie rod is fully adjustable.  If that is the case, am I correct in thinking that only one part number is needed for both sides? - Thanks
    • Whkwikloader
      By Whkwikloader
      Just picked up this 417-8. Plan on tearing it down, cleaning it up, and painting it.
