ebinmaine 79,834 #101 Posted February 11, 2021 Have to say that's quite a machine. We've not yet tried moving dirt more than a skim coat with a front plow so I don't know what the actual capabilities are of them. That said, seems to me that one is getting phenomenal traction because it's pushing quite a fair amount of dirt. 40 minutes ago, Oldskool said: Could you just use ATV tracks? Orientate them to have the lower idler in front or back? Any of the tractors that have bolt on rear wheels you could just have bolt pattern adapters made and then just restructure the stabilizer struts? The hieght change would probably make it a must for skies I'd had the same thought. Only issue with me is that I'd be looking to make something, not buy them. Just my own preference. I did actually see an ATV earlier today that was set up with four of those tracks so I have to assume it was 4WD. The front set of tracks had an idler that was several inches higher at the front than the next set back giving it the ability to crawl over something or pack down snow allowing the rears to just roll on. Not having ever had any experience with machines like this I may be way off base but my mind's eye tells me that I would want the idlers forward of the rear tire and probably as high off the ground as they would be able to go. Six, seven inches? But the step would be in the way..... Share this post Link to post Share on other sites
DennisThornton 4,773 #102 Posted February 11, 2021 1 hour ago, ebinmaine said: If we could come up with a fairly easy to assemble bolt on assembly Trina and I would build it. Here's a fully bolt on but I don't see much "easy to assemble" in it: 1 Share this post Link to post Share on other sites
Oldskool 6,678 #103 Posted February 11, 2021 Just now, ebinmaine said: Have to say that's quite a machine. We've not yet tried moving dirt more than a skim coat with a front plow so I don't know what the actual capabilities are of them. That said, seems to me that one is getting phenomenal traction because it's pushing quite a fair amount of dirt. I'd had the same thought. Only issue with me is that I'd be looking to make something, not buy them. Just my own preference. I did actually see an ATV earlier today that was set up with four of those tracks so I have to assume it was 4WD. The front set of tracks had an idler that was several inches higher at the front than the next set back giving it the ability to crawl over something or pack down snow allowing the rears to just roll on. Not having ever had any experience with machines like this I may be way off base but my mind's eye tells me that I would want the idlers forward of the rear tire and probably as high off the ground as they would be able to go. Six, seven inches? But the step would be in the way..... That brings me back to the idea of putting a smaller wheel on the rear axle then mount the original rear wheel on an axle behind. That would give you the approach angle 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #104 Posted February 11, 2021 Simplest I've found so far. Not the most sturdy but I like the idea. Maybe use a 12" rim with cogs and a heavier spring/shock system. 1 Share this post Link to post Share on other sites
ebinmaine 79,834 #105 Posted February 11, 2021 4 minutes ago, Oldskool said: That brings me back to the idea of putting a smaller wheel on the rear axle then mount the original rear wheel on an axle behind. That would give you the approach angle I like the idea for the configuration of the track setup but the trailer hitch would have to be extended a fair amount. Maybe not a national emergency but another thing to think about. Share this post Link to post Share on other sites
DennisThornton 4,773 #106 Posted February 11, 2021 9 minutes ago, ebinmaine said: Have to say that's quite a machine. We've not yet tried moving dirt more than a skim coat with a front plow so I don't know what the actual capabilities are of them. That said, seems to me that one is getting phenomenal traction because it's pushing quite a fair amount of dirt. I'd had the same thought. Only issue with me is that I'd be looking to make something, not buy them. Just my own preference. I did actually see an ATV earlier today that was set up with four of those tracks so I have to assume it was 4WD. The front set of tracks had an idler that was several inches higher at the front than the next set back giving it the ability to crawl over something or pack down snow allowing the rears to just roll on. Not having ever had any experience with machines like this I may be way off base but my mind's eye tells me that I would want the idlers forward of the rear tire and probably as high off the ground as they would be able to go. Six, seven inches? But the step would be in the way..... Same experience as you and I have the same thoughts. For traction I think I'd want a forward idler above ground. Thinking it and doing is a bit different. Clearance issues abound! But, doable one way or the other, but at a cost. Share this post Link to post Share on other sites
DennisThornton 4,773 #107 Posted February 11, 2021 6 minutes ago, Oldskool said: That brings me back to the idea of putting a smaller wheel on the rear axle then mount the original rear wheel on an axle behind. That would give you the approach angle Can't remember seeing that if I have... New approach to me. The problem is not the lack of ideas but rather to narrow them down while picking the best OR coming up with a new one, which you might have just done. Put the clearance issue in the back where there's plenty of room! Share this post Link to post Share on other sites
Oldskool 6,678 #108 Posted February 11, 2021 Just now, ebinmaine said: I like the idea for the configuration of the track setup but the trailer hitch would have to be extended a fair amount. Maybe not a national emergency but another thing to think about. Depending on the length of track, yes. A bit longer hitch and a bit longer tongue on the trailer. Dont try to make it up in one spot. 1 Share this post Link to post Share on other sites
ebinmaine 79,834 #109 Posted February 11, 2021 I like that hensu setup 2 Share this post Link to post Share on other sites
Oldskool 6,678 #110 Posted February 11, 2021 Just now, DennisThornton said: Can't remember seeing that if I have... New approach to me. The problem is not the lack of ideas but rather to narrow them down while picking the best OR coming up with a new one, which you might have just done. Put the clearance issue in the back where there's plenty of room! That design will gear things down a bit and add more power. I could see an 8 speed being used 1 Share this post Link to post Share on other sites
Oldskool 6,678 #111 Posted February 11, 2021 I'm thinking that track construction may be the biggest question. I could wonder what's the easiest, cheapest, most durable way to do it, but I doubt you can have it all. Share this post Link to post Share on other sites
Oldskool 6,678 #112 Posted February 11, 2021 4 minutes ago, DennisThornton said: Can't remember seeing that if I have... New approach to me. The problem is not the lack of ideas but rather to narrow them down while picking the best OR coming up with a new one, which you might have just done. Put the clearance issue in the back where there's plenty of room! That's the idea you had to lay down on the floor to envision lol 1 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #113 Posted February 11, 2021 (edited) I'm trying to get a few things done around here and still check in as I can. Just saw this: Worth taking a look. Has several neat ideas and doesn't even have tracks! Yet! Here I've been all about tracks but this has really gotten my attention; And then a follow up in the mud. He eventually got stuck but still quite impressive. Edited February 11, 2021 by DennisThornton added a vid 1 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #114 Posted February 11, 2021 Just now, Oldskool said: That's the idea you had to lay down on the floor to envision lol Why I haven't seen it yet! And perhaps I wasn't lying quite correctly... 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #115 Posted February 11, 2021 2 minutes ago, Oldskool said: I'm thinking that track construction may be the biggest question. I could wonder what's the easiest, cheapest, most durable way to do it, but I doubt you can have it all. Right now, subject to change after my next find. I think metal cleats and chains holding them together. Use on cogs or rubber tires. 1 Share this post Link to post Share on other sites
ebinmaine 79,834 #116 Posted February 11, 2021 18 minutes ago, Oldskool said: That design will gear things down a bit and add more power. I could see an 8 speed being used probably would have to downsize the transmission pulley to make up for some lack of top speed Share this post Link to post Share on other sites
DennisThornton 4,773 #117 Posted February 11, 2021 22 minutes ago, ebinmaine said: probably would have to downsize the transmission pulley to make up for some lack of top speed Depends on usage. I plow snow with my C-85 for final cleanup in Hi/Hi and at times would want more speed but if I'm thinking dozer my mind slows down for some reason. Lo/Lo in all my tractors has gotten me unstuck and kept me from spinning and getting stuck. I'd settle for less speed on a tracked vehicle. Others might want a "RipSaw". 1 Share this post Link to post Share on other sites
Oldskool 6,678 #118 Posted February 11, 2021 24 minutes ago, ebinmaine said: probably would have to downsize the transmission pulley to make up for some lack of top speed Maybe so, but just how fast we wanting to go in this mode. I could see where it could go 1/3 slower on top end. 2 Share this post Link to post Share on other sites
Oldskool 6,678 #119 Posted February 11, 2021 Just now, DennisThornton said: Depends on usage. I plow snow with my C-85 for final cleanup in Hi/Hi and at times would want more speed but if I'm thinking dozer my mind slows down for some reason. Lo/Lo in all my tractors has gotten me unstuck and kept me from spinning and getting stuck. I'd settle for less speed on a tracked vehicle. Others might want a "RipSaw". I believe that is a Maine based business. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #120 Posted February 11, 2021 Just now, Oldskool said: I believe that is a Maine based business. Maybe you could spy on them? Get some samples too? 2 Share this post Link to post Share on other sites
Oldskool 6,678 #121 Posted February 11, 2021 When I worked at a local peat bog gears were your friend. Slow, you were going. Fast, you made enemies. Cause you just made a mess of things 1 Share this post Link to post Share on other sites
Oldskool 6,678 #122 Posted February 11, 2021 Just now, DennisThornton said: Maybe you could spy on them? Get some samples too? They are closer to Eric lol 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #123 Posted February 11, 2021 3 minutes ago, Oldskool said: They are closer to Eric lol Ahh! Tag team spy can carry more back! 1 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #124 Posted February 11, 2021 5 minutes ago, Oldskool said: When I worked at a local peat bog gears were your friend. Slow, you were going. Fast, you made enemies. Cause you just made a mess of things As I've gotten older I've noticed that sometimes slower is faster. But I still sometimes get temporarily stuck. 2 Share this post Link to post Share on other sites
ebinmaine 79,834 #125 Posted February 11, 2021 39 minutes ago, Oldskool said: I believe that is a Maine based business. Didn't realize what that was until I googled it. Been by it many times. They have one on display out at the front. 1 Share this post Link to post Share on other sites
