lobo 23 #1 Posted February 8, 2021 Did a rebuild on a 16hsp Kohler, everything went well except now it will sit and idle for about 10mins. or so and then it starts to sputter and almost die then run smooth again for about the same and starts all over again. Tried draining the gas tank, put fresh gas in it, made sure the fuel was going through, changed the coil and it hasn't made a difference. Was hoping that someone has an idea of what's going on? Share this post Link to post Share on other sites
squonk 45,536 #2 Posted February 8, 2021 Dirty Carb Share this post Link to post Share on other sites
pfrederi 19,897 #3 Posted February 8, 2021 Is this a new Chinese carb?? I have had problems with them. It may run fine at full throttle but has idle issues. Could all so be dirt in the idle circuit. Doubt it was the coil but hook up a spark plug tester and see if the flashing changes a lot during the rough phase. Share this post Link to post Share on other sites
Handy Don 15,950 #4 Posted February 8, 2021 Wondering if the float valve is getting hung up 1 Share this post Link to post Share on other sites
Bill D 2,598 #5 Posted February 9, 2021 K series or M series. Possible points and condenser issue. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #6 Posted February 9, 2021 The mixture screw settings are just to make the engine run. They must be fine tuned for best performance after warmup. Garry 1 Share this post Link to post Share on other sites
lobo 23 #7 Posted May 5, 2021 Okay I'm back, did a rebuild and cleaned the carb, replaced the points and condenser, tried another coil, now don't have spark to the plug. I've got power to both sides of the coil, no spark to the plug. It was running the same way as before just before I replaced the points and condenser and now I'm at my wits end. Any advice now would be helpful. Share this post Link to post Share on other sites
pfrederi 19,897 #8 Posted May 5, 2021 32 minutes ago, lobo said: Okay I'm back, did a rebuild and cleaned the carb, replaced the points and condenser, tried another coil, now don't have spark to the plug. I've got power to both sides of the coil, no spark to the plug. It was running the same way as before just before I replaced the points and condenser and now I'm at my wits end. Any advice now would be helpful. If you have 12v to the coil and no spark go back to you points. Do they open an close as you crank? Better yet hook up a test light. from the negative coil terminal to ground then crank does it flash on and off??? Share this post Link to post Share on other sites
lobo 23 #9 Posted May 5, 2021 my points open and close as they should, but will try the test light tomorrow Share this post Link to post Share on other sites
lobo 23 #10 Posted May 10, 2021 tried the test light and I've got spark at the time it's doing the coughing and choking, had one of those brain farts is why I didn't have spark to the plug. I just have no idea what is going on with this but this time it died. It's not one of those China carbs. Share this post Link to post Share on other sites
lobo 23 #11 Posted May 11, 2021 I guess nobody has anymore ideas either. I've got alot of wheelhorse equipment that I am considering getting rid of as I'm getting fed up with trying to keep these running. Share this post Link to post Share on other sites
pfrederi 19,897 #12 Posted May 11, 2021 How are you testing for spark Just laying it on the head while you crank or a spark plug tester? You have replaced a lot of stuff. Try a plug wire from one of you other pieces of equipment that works. also i would try a new plug Autolite 216 Share this post Link to post Share on other sites
lobo 23 #13 Posted May 11, 2021 I've put a new plug in it already, got a spark tester, tried the spark plug wire off my C-161, I know it is good. Like I said it runs fine till it warms up some, sure got me scratching my head. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #14 Posted May 12, 2021 May be worth checking the valve adjustment. Too tight will do that. Garry Share this post Link to post Share on other sites
seuadr 489 #15 Posted May 13, 2021 when it dies, is the carb bowl full? Share this post Link to post Share on other sites
lobo 23 #16 Posted May 13, 2021 I haven't checked to see if the bowl is full but I have checked that it is pumping gas, plan on checking the valve clearance today. Share this post Link to post Share on other sites
ranger 1,840 #17 Posted May 13, 2021 What’s the temperature where you are? I had a service van once that had a Weber economy carburettor fitted. It would run all day at high speed, but if you then backed off the throttle it would splutter, and die. We couldn’t find any reason why. It would usually fire up immediately? One day it played up, I stopped, pulled the hood, and jumped out, just in time to see a coating of ‘Ice’ flash off the outside of the carb. The economy carb had a smaller bore than original, the increased air speed through was cooling the carb to the point, icing was occurring when the butterfly closed on the overrun. You mentioned rebuilding the engine? Did you renew the valves? The reason I ask is I remember something about the early “Magnum” engines suffering from exhaust valves binding in the guides when hot, and dealers having to ream the guides to a looser fit. My 312-8 has, I believe, this problem, runs fine in the cooler weather, will pop and bang when worked hard for a while then cut out. Will spin over on the starter very fast, as though no compression, leave it for a minute or two, and it will fire up and run again for a while, then repeat the fun and games. If I run at 3/4 throttle it runs for longer. I’ve changed just about everything on the tractor, no change. Share this post Link to post Share on other sites
lobo 23 #18 Posted May 14, 2021 Okay, I re-adjusted the valves yesterday, thought it was working then it started to do the same thing just took longer. When it starts to cough and sputter you can reach up and give it gas, it then coughs up some black smoke and runs fine for awhile, then back to the same. I'm starting to think it's the carb, maybe the rebuild kits I got off flea bay thought I was getting a good deal with a lot of 5, could be China crap. Guess i will try getting a kit from the shop and see if that's it. Share this post Link to post Share on other sites
