Ken m 0 #1 Posted February 2, 2021 I have a 312-8 with a snowblower. The tube stud is worn to the cutter pin hole so I can't use the snowblower, tube keeps falling off.Any suggestions? I was thinking about drilling a new hole or threading the stud and use a nut. Also blower doesn't throw the snow very far. Any way to adjust. Share this post Link to post Share on other sites
Darb1964 1,129 #2 Posted February 3, 2021 Spray the shoot with Teflon, tighten the power take off belt or replace it if worn or glazed. The Chan and sprocket may be warn out. Share this post Link to post Share on other sites
Darb1964 1,129 #3 Posted February 3, 2021 I would check the ware blade, sounds like it may be warn out so your bar is dragging. Share this post Link to post Share on other sites
lynnmor 8,307 #4 Posted February 3, 2021 Take the tube to a weld shop and they can make it like new. Follow the directions in the manual to get the right washer and pin, a certain amount of slop is needed. Are you running the engine full throttle? Share this post Link to post Share on other sites
Ken m 0 #5 Posted February 3, 2021 2 hours ago, lynnmor said: Take the tube to a weld shop and they can make it like new. Follow the directions in the manual to get the right washer and pin, a certain amount of slop is needed. Are you running the engine full throttle? I have a neighbor that welds, he's going to take a look at it Share this post Link to post Share on other sites
Ken m 0 #6 Posted February 3, 2021 2 hours ago, Darb1964 said: Spray the shoot with Teflon, tighten the power take off belt or replace it if worn or glazed. The Chan and sprocket may be warn out. Will look at the belt, not sure when it was last replaced, just got the snowblower Share this post Link to post Share on other sites
