moe1965 766 #1 Posted February 2, 2021 I have a c-141 I used it yesterday to plow my driveway today it will not do anything battery is up 100% is there any way to bypass safety switches to see if that is the issue Share this post Link to post Share on other sites
pfrederi 18,771 #2 Posted February 2, 2021 PTO unegaged?? (wouldn't be the first time for me) Use jumper from Battery + to the starter motor. she crank??? 2 Share this post Link to post Share on other sites
moe1965 766 #3 Posted February 3, 2021 I jumped the selonide with screwdriver it started using the key the solenoid does not even click. Would that be the issue. Or is a safety switch preventing that. Share this post Link to post Share on other sites
953 nut 60,696 #4 Posted February 3, 2021 Please resist the temptation to blame it on safety switches and bypass them. Use a small jumper wire from the battery "+" to the small terminal on the solenoid. This should close the solenoid and turn over the starter, if not the solenoid is probably the problem. If the solenoid works as it should take a look at the rest of your wiring. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #5 Posted February 3, 2021 1 Share this post Link to post Share on other sites
