JJ Barnett 1 #1 Posted February 1, 2021 Does a volt meter from a 86 417a work on a 88 520h? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,986 #2 Posted February 1, 2021 They use different part numbers so do not know if it will fit. 1986 417-A uses 110741 replaced by 117176 and no longer available. 1988 520-H uses 113468 replaced by 79-0060 and still available from Toro. Garry Share this post Link to post Share on other sites
pfrederi 19,807 #3 Posted February 1, 2021 I would assume they are 2 " gauges the difference is probably the type of terminal spade screw etc... Share this post Link to post Share on other sites
lynnmor 8,581 #4 Posted February 1, 2021 Some have the needle swing from the top, others from the bottom, that may be the only difference. Share this post Link to post Share on other sites
Handy Don 15,772 #5 Posted February 1, 2021 Some are illuminated and some not, as well Share this post Link to post Share on other sites
