tallen4392 71 #1 Posted January 31, 2021 Hi my c-81 has been running great used it to plow my driveway last storm. but today it was 4 degrees this am my tractors don't like to start very easy when it is that cold it cranked a little bit but would not fire up now the selenide only clicks when I turn the key no crank I tried taking the wire off the starter the short one from the selenide the thing still only clicks is the selenide bad never had one do that with the wire to the starter unhooked big storm coming tomorrow of corse not much time to fart around with it and no heat in the garage any idea I have a new selenide but it has two large terminals and two small the one on it has 1 small terminal 1 Share this post Link to post Share on other sites
pfrederi 19,974 #2 Posted February 1, 2021 (edited) Quick fix for tomorrow, turn your ignition switch to run. use your jumper cable to go from battery + to the terminal on the starter motor. She should crank and if she is otherwise OK fire up. Just don't turn her off while plowing Hint spray a bit of gas or carb cleaner into the carb before you try this. Edited February 1, 2021 by pfrederi 2 Share this post Link to post Share on other sites
R Scheer 510 #3 Posted February 1, 2021 You could also use your jumper cables to jump the 2 big connectors. If it cranks then you know the problem is in the solenoid. Share this post Link to post Share on other sites
Achto 31,169 #4 Posted February 1, 2021 One more thing to check - Is your battery at full charge? I low battery may allow the solenoid to close but there may not be enough juice to turn the engine over. 4 Share this post Link to post Share on other sites
953 nut 64,393 #5 Posted February 1, 2021 It could be a battery that is not up to the task anymore or it could be the electrical connections have some corrosion or are not tight. As for the four wire solenoid see the photo below Share this post Link to post Share on other sites
squonk 45,664 #6 Posted February 1, 2021 Check your battery state of charge with a volt meter. I've seen more bad batteries than bad solenoids. 1 Share this post Link to post Share on other sites
peter lena 9,785 #7 Posted February 1, 2021 tallen, that 4 deg zone is probably your issue , do you have a battery tender ? I regularly use mine to verify my battery state , also agree with others on areas to check for a start , I also use a light bulb with reflector under my engines during cold weather , adds a slight amount if heat to the engine that really helps cold starting , pete Share this post Link to post Share on other sites
tallen4392 71 #8 Posted February 1, 2021 the battery is new and new cables at the same time I will try the light thing when it is real cold they do not fire right up I am going to go out there in a little bit I put the charger on the battery last night but I don't think it is the battery or cables I also tightened all the cables yesterday Share this post Link to post Share on other sites
Rob R 988 #9 Posted February 1, 2021 Besides all the good advice that was given consider purchasing a KATS magnetic block heater.... I use this all the the time when it is that cold put it on like 2 hours before you go out (or do the walkways while its heating) BIG difference in cranking and saving the starter. Also take out the spark plug heat it up on the wood stove, heat gun or butane fire starter add a squirt of 2 cycle gas and you'll be amazed how much better the ole girl will pop off...... p.s. a poor mans method of heating the block use an old plug in bulb (75 watt) automotive light put it next to the block and cover the engine with a tarp again a couple of hours before you go out. Just saying have been doing this for like 45 yrs. Share this post Link to post Share on other sites
tallen4392 71 #10 Posted February 1, 2021 All good advice thanks Share this post Link to post Share on other sites
tallen4392 71 #11 Posted February 2, 2021 Kats heater how do those work you just stick it to the engine and plug it in ???? Share this post Link to post Share on other sites
pfrederi 19,974 #12 Posted February 2, 2021 9 hours ago, tallen4392 said: Kats heater how do those work you just stick it to the engine and plug it in ???? Yes. Share this post Link to post Share on other sites
Rob R 988 #13 Posted February 2, 2021 10 hours ago, tallen4392 said: Kats heater how do those work you just stick it to the engine and plug it in ???? Yes sir as stated takes a couple of hours but does a great job....... Share this post Link to post Share on other sites
