Gregor 4,848 #1 Posted January 31, 2021 The 656 will push some snow, but that wet stuff we got this morning was quite a challenge. 6 Share this post Link to post Share on other sites
Ed Kennell 46,411 #2 Posted January 31, 2021 A can of Regal Red would make it perfect. 4 Share this post Link to post Share on other sites
Gregor 4,848 #3 Posted January 31, 2021 2 hours ago, Ed Kennell said: A can of Regal Red would make it perfect. That will have to wait until spring. 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #4 Posted January 31, 2021 Challenge... Maybe.. Looks like it did do it though. Maybe time for you to do a fabrication project ?? Build-your-own-plow.... Share this post Link to post Share on other sites
Gregor 4,848 #5 Posted January 31, 2021 9 minutes ago, ebinmaine said: Challenge... Maybe.. Looks like it did do it though. Maybe time for you to do a fabrication project ?? Build-your-own-plow.... Do you think I got that one at Walmart? 2 Share this post Link to post Share on other sites
ebinmaine 79,420 #6 Posted January 31, 2021 32 minutes ago, Gregor said: Do you think I got that one at Walmart? I should rephrase that a bit. Build-your-own-plow.... Frame. And bigger blade. Share this post Link to post Share on other sites
JMcBrew 58 #7 Posted February 1, 2021 Had my first chance to push snow with the Raider today! The blade is some off-brand, DIY setup that came with my WH when I bought it last year. It works okay, but I can’t raise it enough to lock it in the up position, so I have to turn the adjustment knob a bunch of turns if I want it to stay off the ground. The video was taken before I was comfortable enough to run in 6th gear. I also put on the tire chains that I got from the previous owner. He had never used the blade or the chains. They came to him from the original owner. 3 Share this post Link to post Share on other sites
