Irv 115 #1 Posted May 26, 2009 Anyone know where I can get gator blades for a 42" sd deck? thanks Share this post Link to post Share on other sites
C-Series14 15 #2 Posted May 26, 2009 Too easy, got mine here.... http://www.jackssmallengines.com/gattoro.cfm Share this post Link to post Share on other sites
Duff 206 #3 Posted May 27, 2009 ...and once you've got 'em, it'll spoil you for just about every other blade out there. I'm running them on three tractors now (two non-WH, unfortunately), mowing about 4 acres every 5-6 days, and they are amazing! Seem to hold an edge better than most, too! (The preceding is NOT a paid advertisement!) Duff :omg: Share this post Link to post Share on other sites
munsonRN 0 #4 Posted May 27, 2009 How about for a 42" RD deck? I've looked at a few different places but can't seem to find them. Thoughts? Share this post Link to post Share on other sites
MaineDad 87 #5 Posted May 27, 2009 It's my understanding that they are not available for the RD decks. Correct? If so, I'm buying a set too! Share this post Link to post Share on other sites
Duff 206 #6 Posted May 28, 2009 How about for a 42" RD deck? I've looked at a few different places but can't seem to find them. Thoughts? Guys, if you can get me the measurements from one of your 42" RD blades I'll do some digging around. There are a couple of suppliers who have huge inventories of these blades for a whole range of mowers and somewhere there's got be a close enough match to work. I'll need the length and as exactly as you can get it (within 1/64th), the diameter of the center hole (are they round, "D" or "double "D" shaped?). Since I don't know anything about these decks, how much clearance is there between the upper surface of the blade and the underside of the deck shell? Gator blades do have a pretty radical upsweep at the ends where the mulching tips are located! Duff :omg: Share this post Link to post Share on other sites
04fxdwgi 0 #7 Posted May 28, 2009 Got mine here: https://www.baileysonline.com Here is the link to Oregon, makers of the Gators. PDF's have all the specs and you can match em up. Use the part number then search web for them: http://www.oregonchain.com/OEP/oep_blades.htm Share this post Link to post Share on other sites
GlenPettit 1,718 #8 Posted May 28, 2009 No difference in the three Gator blades for a 42" RD or SD deck. Share this post Link to post Share on other sites
Duff 206 #9 Posted May 28, 2009 Got mine here: https://www.baileysonline.com Here is the link to Oregon, makers of the Gators. PDF's have all the specs and you can match em up. Use the part number then search web for them: http://www.oregonchain.com/OEP/oep_blades.htm Yup, Bailey's is where I got mine, too. Good outfit! Duff :omg: Share this post Link to post Share on other sites
munsonRN 0 #10 Posted May 29, 2009 Hmm. I've looked at many different webpages and can't seem to find them. The following are the specs from one of the web pages. Blade Length 14-1/2" (36.8cm) Blade Width 2" (5.1cm) Blade Thickness .203" (5.15mm) Center Hole Diameter 3/4" (19mm) (ROUND) I will have to measure the distance from the deck to blade as I am unsure as I sit here at work. Share this post Link to post Share on other sites
04fxdwgi 0 #11 Posted May 29, 2009 Hmm. I've looked at many different webpages and can't seem to find them. The following are the specs from one of the web pages. Blade Length 14-1/2" (36.8cm) Blade Width 2" (5.1cm) Blade Thickness .203" (5.15mm) Center Hole Diameter 3/4" (19mm) (ROUND) I will have to measure the distance from the deck to blade as I am unsure as I sit here at work. I see what you mean. That size doesn't fit ANY mower manufacturer for a Gator blade. Share this post Link to post Share on other sites
KyBlue 655 #12 Posted May 29, 2009 I've got a set on my 36" RD Deck...really wonder if they didnt put a set on from a SD Deck, thou the TORO MPV lists two different sets of blades for the SD and RD decks.. Share this post Link to post Share on other sites
d180man 5 #13 Posted May 29, 2009 Hi if you have a part # we can get them if they still make them or we can get some like Gator blades but thanks have a nice day! :omg: Share this post Link to post Share on other sites
munsonRN 0 #14 Posted June 1, 2009 The wheelhorse/toro model # is 106635. Three are used to fit the deck. Share this post Link to post Share on other sites
gwgdog66 23 #15 Posted June 2, 2009 No difference in the three Gator blades for a 42" RD or SD deck. Share this post Link to post Share on other sites
Irv 115 #16 Posted June 2, 2009 Toro parts viewer lists same blades for 42" sd or rd deck. Gator part # is 90643. The Gator blades are sold individually. Share this post Link to post Share on other sites
munsonRN 0 #17 Posted June 2, 2009 http://www.jackssmallengines.com/gatToro.cfm The specs on that blade are different than the specs for the 42" RD. The blade for the RD is 14 1/2 inches and that spec says 13 27/32. Hmmmm... Share this post Link to post Share on other sites
GlenPettit 1,718 #18 Posted June 4, 2009 Re: Having two blades on each spindle, loosening. The nuts do not loosen, but the blades may not always stay at 90 Share this post Link to post Share on other sites
Jedakiego 0 #19 Posted June 4, 2009 The specs on that blade are different than the specs for the 42" RD. The blade for the RD is 14 1/2 inches and that spec says 13 27/32. Hmmmm... I have a 42 inch RD that I am rebuilding from rust holes and a 42 inch SD that I use on the lawn. There are deffinatley 2 different blades. If you put the 14 1/2 inch blades from the RD on the SD they hit each other. Share this post Link to post Share on other sites
