ericj 1,580 #26 Posted February 1, 2015 there is a neutral safety switch under the steering wheel. take the bottom dash plate off and you should be able to see it though i doubt that you would have knocked the wires off of it, but it is possible or the little metal tab might have broken off. but it sounds like you knocked wires off some were along the line causing the no start problem. down load the onan service manual , it will tell you how to check for spark and other short cuts to eliminate possible problems. also you might want to down load the manual for your tractor witch will have a wiring diagram that should help you check it out further. eric j 1 Share this post Link to post Share on other sites
randyh 4 #27 Posted February 2, 2015 is your lever on the steering column ? 1 Share this post Link to post Share on other sites
Crawdad 5 #28 Posted February 2, 2015 Yes, the lever is on the steering column. Share this post Link to post Share on other sites
Crawdad 5 #29 Posted February 2, 2015 Thanks Eric, That sounds like a good place to begin. I was going to check the fuses as I recall getting a spark when I hastily tried to reset the ecentric a 2nd time. I'll let you know when I resolve the issue, (we now have 9 inches fallen and of course 2' in front of the entrance. Share this post Link to post Share on other sites
ericj 1,580 #30 Posted February 2, 2015 if you had a spark you might have very well pop a fuse so check that 1 st eric j Share this post Link to post Share on other sites
Crawdad 5 #31 Posted April 19, 2015 Yeah, Just popped the fuse- well actually melted it! Had to cut away the plastic body of the fuse that adhered to the plug box. all is good now. Share this post Link to post Share on other sites
