Countdown To Christmas!
Docwheelhorse
Post # 2... Why.... Why do idiots do this... WHY
Docwheelhorse
Bought a brand new 7473 belt ($46) for my C160 because it wasn't shifting right and squeeled alot... saw it was one of those Green Gates cheater belts and figured that was issue. Decided to do a full service as I knew transaxle had water... siggghhhh
THE NEW BELT DOESNT FIT.... WTH???
OH!!! SOME IDIOT BEING CUTE PUT A HYDRO 5" PULLEY ON ENGINE.
Now I get to try and get it off without wrecking anything and I need to find an 8 speed 1 1/8 crank pulley to make it right.
Some people should not have tools or Wheel Horses...
Stay Safe Everyone
Tony
  • Sad 2
AMC RULES
Is that the same W-H you shot full of holes today Tony?
  • Haha 1
Docwheelhorse
I couldn't did it THEN... but im seriously contemplating NOW
AMC RULES
I've read here in the past...that this is part of the fun we assume when collecting these things.  :blink: :blink:
  • Like 5
WHNJ701
Your name is Doc wheelhorse? Dr.?
wallfish
Just leave that pulley on there and enjoy the extra speed. I've never had any problems at all using the TSC kevlar belts to drive a tractor. The squealing is probably caused from the frozen water in the trans. Clean the pulley surfaces
  • Like 5
Handy Don
1 hour ago, Docwheelhorse said:
Water you say? Looks more like a Starbucks mocha latte to me!
  • Haha 2
Docwheelhorse
No frozen water... its been squeeling for the 6 months I've owned it and it just doesn't de-clutch correctly... it grinds the gears when shifting in. It will be corrected
rjg854
All I can say about that gear oil is WOW :scared-eek:
953 nut
Bad idler?   Lack of a bet guard?   Engine drive pulley belt guide missing?
520HC
Yeah more idiots think they know how to "fix" wheel horses everyday. Like you, I also want mine to work correctly.
  • Confused 1
squonk
Harmonic balancer puller will get that pulley off
Retired Wrencher
Tony I have seen worse than that for tranny fluid. The chunky kind. I have frozen 4 speeds come back to life by flushing them out.
clueless
That how the cream color Behr interior paint that I painted the living room with last weekend looked before I stirred it ;).
  • Haha 1
71_Bronco
Did it have a belt guard on it? Can't imagine it would have fit without modification since the angles of the belt would be wrong.
As others have said, belt guards help keep the belt in place and help disengage the belt when the clutch is pressed in (im sure you already knew that though).
Docwheelhorse
No... no and no... but yes to incorrect engine pulley for 8 speed
Edited by Docwheelhorse
Maxwell-8
I came to the conclusion, some idiot welded the hubs to the axles. :angry-cussingwhite:
Meanwhile the axle-seals are leaking.:angry-steamingears:
  • Sad 1
AHS
You probably have already done this, but make sure to replace the shifter boot... to make sure any milky stuff doesn’t come out of the tranny later in life!
Tuneup
The toughest part for a new owner is knowing what is stock and what is not. You found the larger pulley. I would not have had a clue. Nice attention to detail!
