RandyLittrell 3,945 #51 Posted January 10, 2021 Here is some very good priced tires. Don't know anything about them, but the price is right. https://smile.amazon.com/23x8-50-12-Tractor-8-50-12-23-8-50-12-Tubeless/dp/B07X3BJ41P/ref=sr_1_5?crid=3OXH80KCEB7R0&dchild=1&keywords=23x8.50-12+tractor+tires&qid=1610319194&sprefix=23x8%2Caps%2C203&sr=8-5 Randy 4 Share this post Link to post Share on other sites
TJ5208 1,841 #52 Posted January 11, 2021 well im glad to know that i wont bend the axle Share this post Link to post Share on other sites
TJ5208 1,841 #53 Posted January 11, 2021 what kind of bushings Share this post Link to post Share on other sites
TJ5208 1,841 #54 Posted January 11, 2021 i have a question can you fill tires without a tube Share this post Link to post Share on other sites
Achto 32,633 #55 Posted January 11, 2021 12 minutes ago, Tj salyers said: i have a question can you fill tires without a tube Yes, if you use RV antifreeze or Rim Saver fluid Share this post Link to post Share on other sites
TJ5208 1,841 #56 Posted January 11, 2021 Okay do you have one with rv antifreeze Share this post Link to post Share on other sites
Achto 32,633 #57 Posted January 11, 2021 19 minutes ago, Tj salyers said: what kind of bushings For the axle spacers some thing on this line would work. Important dimensions will be inside diameter (3/4 inch) and the length that you need. https://www.lowbrowcustoms.com/products/3-4-inch-id-x-3-4-inch-long-aluminum-motorcycle-wheel-axle-spacers-pair?variant=31149096370223&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=EAIaIQobChMIspW7mpGU7gIVpuHACh1giAeqEAQYCSABEgJG7vD_BwE Share this post Link to post Share on other sites
TJ5208 1,841 #58 Posted January 11, 2021 Can you find it on amazon because I can't use any other site because of visa cards Share this post Link to post Share on other sites
TJ5208 1,841 #59 Posted January 11, 2021 But I regularly buy a amazon card at the store Share this post Link to post Share on other sites
TJ5208 1,841 #60 Posted January 11, 2021 Im at my braces appointment I have internet my phone does not have a SIM in it I have a chromebook but have no internet at home except a little box Verizon box that don't have much WiFi on it hope you guys understand Share this post Link to post Share on other sites
Achto 32,633 #61 Posted January 11, 2021 2 minutes ago, Tj salyers said: Okay do you have one with rv antifreeze I personally do not have any tractors with loaded tires but many people on this forum do run RV antifreeze in their tires. 13 minutes ago, Tj salyers said: Can you find it on amazon because I can't use any other site because of visa cards If you search (3/4" i.d. axle spacers) on Amazon, I'm sure that you find some thing. Share this post Link to post Share on other sites
TJ5208 1,841 #62 Posted January 11, 2021 I'll have to measure the gap so I can get the right one Share this post Link to post Share on other sites
TJ5208 1,841 #63 Posted January 11, 2021 The best thing is the bearings stick out so that will help I might use washers what do you guys think Share this post Link to post Share on other sites
Achto 32,633 #64 Posted January 11, 2021 2 minutes ago, Tj salyers said: I might use washers what do you guys think Washers will work with no problem. Post a picture of your original rims. I'll be able to tell you if the Deestones will fit on to your original rims. Might be able to save the hassle of spacing out the rims that you showed us. Share this post Link to post Share on other sites
TJ5208 1,841 #65 Posted January 11, 2021 Well thought it would look wierd both to go leaving internet Share this post Link to post Share on other sites
TJ5208 1,841 #66 Posted January 11, 2021 I liked the thinner rims Share this post Link to post Share on other sites
Achto 32,633 #67 Posted January 11, 2021 The rims that are on the front of your tractor are the exact same rims that are on my 1076 and Raider 12. The Deestones will fit those with no issues. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #68 Posted January 11, 2021 Here's a picture Share this post Link to post Share on other sites
TJ5208 1,841 #69 Posted January 11, 2021 Thanks Dan aleast I know that now 1 Share this post Link to post Share on other sites
TJ5208 1,841 #71 Posted January 11, 2021 the rims on ole red is 16 6 50 8 Share this post Link to post Share on other sites
Achto 32,633 #72 Posted January 11, 2021 That is the tire size. The rim will only be 4.5 to 5 inches wide. If you look at the picture of my C-141 that I sent you. You can see that those rims have a deep dish & are a lot wider. The C-141 rims would not work with the Deestones. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #73 Posted January 12, 2021 so are you saying dan they wont work. do you guys think they would look wierd on 16 6 50 8 rims or should i stick with the thin rims. i get my braces off next time i always picked grey i choise red this time for wheel horse i thought since this is my last time id do it thanks for all the help everyone 1 Share this post Link to post Share on other sites
Achto 32,633 #74 Posted January 12, 2021 (edited) 1 hour ago, Tj salyers said: so are you saying dan they wont work. do you guys think they would look wierd on 16 6 50 8 rims or should i stick with the thin rims. i get my braces off next time i always picked grey i choise red this time for wheel horse i thought since this is my last time id do it thanks for all the help everyone The Deestones should work and look fine on the original rims that were on the tractor. If you are still uncertain, mount one new tire on to the original rims and see how it looks. If you don't like the look then remove the tire & mount them both on the other rims. I like the red braces idea!! Edited January 12, 2021 by Achto 1 Share this post Link to post Share on other sites
TJ5208 1,841 #75 Posted January 12, 2021 thanks it is my last time ill get my braces off next time 6 weeks what happens if the tire streches will it still fit Share this post Link to post Share on other sites
