TJ5208 1,841 #1 Posted January 7, 2021 what size tires would fit the front wheel horse rims for tri ribbed tires or would i have to change the rims thank you for help Share this post Link to post Share on other sites
ebinmaine 80,638 #2 Posted January 7, 2021 If I remember correctly that's an older Wheel Horse you've got there. Seems like a 4.80 x 8 should work fine. Use tubes and it would be nice and easy to set the bead. 2 1 Share this post Link to post Share on other sites
Achto 32,633 #3 Posted January 7, 2021 Either of the tires listed below will fit the rims on the older tractors. https://www.amazon.com/4-00-8-4-00x8-Deestone-Tires-Tubes/dp/B01BPGCEEM https://www.millertire.com/16x6-50-8-firestone-3-rib-front-tractor-tire-4-ply/ 2 1 Share this post Link to post Share on other sites
ebinmaine 80,638 #4 Posted January 7, 2021 55 minutes ago, Achto said: Either of the tires listed below will fit the rims on the older tractors. https://www.amazon.com/4-00-8-4-00x8-Deestone-Tires-Tubes/dp/B01BPGCEEM https://www.millertire.com/16x6-50-8-firestone-3-rib-front-tractor-tire-4-ply/ Good price on those deestones Dan. Do we know if they run true to size? 1 Share this post Link to post Share on other sites
TJ5208 1,841 #5 Posted January 7, 2021 (edited) thanks guys i'll look into them i appreciate the help very much not very popular on here so thanks for responding i might ask more questions soon also im only aloud to use amazon because of visa card or stuff tj Edited January 7, 2021 by Tj salyers 1 Share this post Link to post Share on other sites
TJ5208 1,841 #6 Posted January 7, 2021 um what kind of tractor do you have achto Share this post Link to post Share on other sites
Achto 32,633 #7 Posted January 7, 2021 5 minutes ago, ebinmaine said: Do we know if they run true to size? Not sure on the size being true or not. I recently posted a pic of my 1076 with the Deestones on. I'll add some here for a refresher. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #8 Posted January 7, 2021 thanks nice tractor older one to 1 Share this post Link to post Share on other sites
Achto 32,633 #9 Posted January 7, 2021 2 minutes ago, Tj salyers said: um what kind of tractor do you have achto I have multiple tractors ranging from 1960 - 1989. More tractors than I have roof for. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #10 Posted January 7, 2021 do you ever plan of putting a stack on it 1 Share this post Link to post Share on other sites
TJ5208 1,841 #11 Posted January 7, 2021 how about a 800 special like mine 1 Share this post Link to post Share on other sites
Achto 32,633 #12 Posted January 7, 2021 1 minute ago, Tj salyers said: do you ever plan of putting a stack on it Not on that one, I have a couple with stacks though. Share this post Link to post Share on other sites
Achto 32,633 #13 Posted January 7, 2021 (edited) 21 hours ago, Tj salyers said: how about a 800 special like mine My C141 is the same body style as your 800 Special. Edited January 8, 2021 by Achto 1 Share this post Link to post Share on other sites
Chestnut 315 #14 Posted January 7, 2021 I found this place when I was looking for some Ag tires. Deestone looks pretty inexpensive. Of course these don't have the tubes, and I didn't look on this site. Tubes are about $15 a pair on Amazon. https://www.tires-easy.com/4.00-8/deestone-tires/d401-f-2/tirecode/DS5106 4 Share this post Link to post Share on other sites
TJ5208 1,841 #15 Posted January 8, 2021 thanks nice tractor Dan thanks chestnut 1 Share this post Link to post Share on other sites
