chev0545 234 #1 Posted January 6, 2021 where do you measure the width Share this post Link to post Share on other sites
vanillaman 11 #2 Posted January 6, 2021 I measure the width from wing to wing. 42 inches. Dick 2 Share this post Link to post Share on other sites
peter lena 9,108 #3 Posted January 6, 2021 chev, the inside measurement of the intake is 36", making the combo a 36x42 single stage thrower. anything else ?, pete Share this post Link to post Share on other sites
chev0545 234 #4 Posted January 6, 2021 got it thanks Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #5 Posted January 6, 2021 If its a single stage unit they covered the width above, but techinally a snow "thrower" the 2 stage are "blowers" because of the impeller fan blowing the snow out the chute.. 2 versions Berco 38" or 40"? and then the TORO/WH 44". 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,276 #6 Posted January 7, 2021 I think you will find the 42" single-stage snowthrower started out as a 37" model. Snowthrower DNA All have 2 idler sprockets for the drive chain. Started out as 37" wide and the added wings make them 42" wide. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. Snowthrower rear frame mounts in the front of the tractor frame using 2 bushings and a long 3/8-16 x 8-1/2" bolt. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) 2002-2007 model 79362 The Ber-Vac 2-stage models were 38" and 46". Share this post Link to post Share on other sites
Brockport Bill 1,840 #7 Posted January 8, 2022 On 1/7/2021 at 10:00 AM, gwest_ca said: I think you will find the 42" single-stage snowthrower started out as a 37" model. Snowthrower DNA All have 2 idler sprockets for the drive chain. Started out as 37" wide and the added wings make them 42" wide. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. Snowthrower rear frame mounts in the front of the tractor frame using 2 bushings and a long 3/8-16 x 8-1/2" bolt. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) 2002-2007 model 79362 The Ber-Vac 2-stage models were 38" and 46". what are the basic relevant differences between blower 79360 and 79362 -- thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,276 #8 Posted January 10, 2022 In 2002 they started to use an electric pto clutch so suspect the drive pulley diameter was different. The 105-1503 kit includes a driven pulley for the snowthrower so it must be to correct the shaft speed. Just noticed 1994 was the first year for the blower housing replaceable scraper bar. Share this post Link to post Share on other sites
