Countdown To Christmas!
John2189
Tire leak
John2189
I put new tubeless tires on the front of my 656  and the beads leak. They were a bit rusty I sanded smooth but the leak. What do you use to seal them?  I’ve heard of use if elmers rubber cement
RandyLittrell
If I have rusty wheels in the beads, I will clean, wire brush and paint them with a thick enamel to fill in the pits and then use wd40 to seat them. Makes the rubber a little softer. If it still leaks, I run them down to the tire shop and they have some bead sealer they can put on it.
Randy
rj35hunter
Honestly these came new with tubes and the wheels may not be intended to be tubeless but at my work we use the black bead sealer designed for that purpose only and it works very well....all of my original tractors have original tubes in them and holds up very well that way....hope this helps!
ebinmaine
I use tubes in all the tires we change now. No more leaking beads or valve stems. On larger tires it's easier to set the beads too.
To stick with tubeless combine the above answers and they should seal.
  • Excellent 1
Maxwell-8
My grandfather was a ford dealer, he always used Vaseline grease to put tires on the rims. He also says, if the beads still leak, sand more.
If you need to use bead-sealer, you are doing something wrong or something isn't right.
I use them too in all my non-car tires. they are pretty problem free
Edited by Maxwell-8
John2189
I sanded but I didn’t paint them. I will take the tire off and paint the bead.  If it still leak I’ll get bead sealer.
thanks
John
DET
Back in my old service station days we would just put regular grease around the bead if we had a leak.
But I agree with Eric about tubes in anything I am mounting for tractor type tires. A lot less issues down the road.
CCW
I know this sounds like sacrilege, but when I needed new tires I took them off the tractor.  Drove to the tire store and had them mount new tires.  No tire changer, no hassles, no leaks and no hassles.
  • Like 4
rjg854
I think it's a good idea myself to use tubes, mainly because these tires don't require much pressure in them.
ebinmaine
I don't think that's sacrilege at all. There are certain things that certain people like to do and not...
I personally will work on one of these tractors for 12 hours straight and not even blink an eye but I don't change the oil in my own car.
pacer
Heh! that statement is almost verbatim as to what my philosophy is --- $20+ at wally world is little more than the cost of buying the oil/filter (my filter is a bit##!!) And, I also put tubes in everything I got.......
ebinmaine
If I ordered ahead online I could get the oil and filter for right around $20 or so. I have a friend who's a tech and runs his own small shop. He charges me something like $38.
Working on tractors we have two different solid surfaces with heat that I can get them into. Not so for a vehicle. Gravel driveway.
He'd have to nearly double that bill before I think about doing it myself...
Jeff-C175
I've used the can I've got maybe 8 times in the past ten years or so.  32 ounces is a LOT of bead sealer and I don't think you can get it in a smaller can.
I would recommend that you take the wheels with the tires mounted but beads loose to a tire place and ask them if they would throw some sealer on them and air them up for you.
A good shop might even do that for free... or very inexpensively.  Probably less than the 20 you would spend on a can of sealer that would last a lifetime and only get used once or twice
Or, run them over here and I'll fix you up for free.  (yeah, OH is pretty far from NJ!) ;)
Edited by Jeff-C175
