gyanzuk 10 #1 Posted January 5, 2021 Has anybody made an electric lift for a gt 1600. Share this post Link to post Share on other sites
ebinmaine 76,186 #2 Posted January 5, 2021 @KrazeyOlDave is your actuator set up usable in this application? Share this post Link to post Share on other sites
KrazeyOlDave 860 #3 Posted January 5, 2021 16 minutes ago, ebinmaine said: @KrazeyOlDave is your actuator set up usable in this application? Yeah, you can literally use them for anything, given you have room for it. Share this post Link to post Share on other sites
gyanzuk 10 #4 Posted January 6, 2021 On 1/5/2021 at 7:34 AM, KrazeyOlDave said: Yeah, you can literally use them for anything, given you have room for it. I don't have an actuator, I just have the manual lift lever, I was wondering if I could put a electric lift on it. Or do you know where I could find a wheel horse hydralic set up cheap. Share this post Link to post Share on other sites
ebinmaine 76,186 #5 Posted January 6, 2021 23 minutes ago, gyanzuk said: I don't have an actuator, I just have the manual lift lever, I was wondering if I could put a electric lift on it. Or do you know where I could find a wheel horse hydralic set up cheap. I can't remember how much detail I went into in the thread but I'm in the middle of doing a manual to hydraulic changeover on my 1970 Charger Hydro project. At minimum you'll need the hydro Rock shaft, cylinder, valve, and hoses. I'm not familiar with your transmission so I don't know what or if you'd be up against anything there. What I was eluding to with the actuator is something I'm thinking of trying on Trina's 867. I just recently added a front weight bracket to that tractor and I'm looking at adding a vertical linear actuator to that same bracket. 1 Share this post Link to post Share on other sites
