ebinmaine 79,700 #26 Posted January 1, 2021 8 minutes ago, seven said: I'm sorry maybe It does it's a charger 12 hp hydro if I go ahead and put that on it shouldn't damage anything will it? Is it a hydro lift as well? Share this post Link to post Share on other sites
Ed Kennell 46,596 #27 Posted January 1, 2021 If it does have hydraulic lift, and you add the solid link, the blade height will be fixed by the position you set it at. It will still float a small amount depending how tight your lift linkage is. Adding the solid link will not damage anything if the blade trip springs are functional. 1 Share this post Link to post Share on other sites
