TJ5208 1,841 #1 Posted December 21, 2020 (edited) I have some questions to ask how would you put a plow on a 800 special how would it lift up and also pics of exhaust stack pipes and about liquid filled tires here's a pair I'm looking at tj Edited December 21, 2020 by Tj salyers Share this post Link to post Share on other sites
TJ5208 1,841 #3 Posted December 21, 2020 Thanks for the info I'm talking about a brinley plow 1 Share this post Link to post Share on other sites
Achto 30,222 #4 Posted December 21, 2020 1 hour ago, Tj salyers said: Thanks for the info I'm talking about a brinley plow You would need one of these https://wheelhorsepartsandmore.com/hitches-liftkits.html#!/Toro-Wheel-Horse-Brinly-Clevis-Hitch-Sleeve-Hitch/p/84960065/category=23548047 and a rear lift cable. Or a lift rear cable, a slot hitch and one of these https://wheelhorsepartsandmore.com/hitches-liftkits.html#!/Toro-Wheel-Horse-Slot-Hitch-Adapter/p/84960037/category=23548047 The rear lift cable will attach to your rock shaft for raising & lowering the rear implement. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #5 Posted December 22, 2020 What about the 800 special Share this post Link to post Share on other sites
Achto 30,222 #6 Posted December 22, 2020 1 hour ago, Tj salyers said: What about the 800 special Sorry, I stand corrected. I forgot that the 800 special did not have the Uni Drive transmission. I guess some custom fabrication would need to be done for a rear lift. 1 Share this post Link to post Share on other sites
stevasaurus 23,518 #7 Posted December 22, 2020 Check out this to see what is available. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #8 Posted December 22, 2020 Any ideas I'm I could drill some holes in frame couldn't I so I can make a lift Share this post Link to post Share on other sites
