Tc4276 0 #1 Posted December 20, 2020 Please help. I have a 78 c161 . i turn the key on. Nothing. No headlights, no power as if it has no battery. Replaced the battery. Nothing. Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted December 20, 2020 Check your ammeter connections. 1 Share this post Link to post Share on other sites
Tc4276 0 #3 Posted December 20, 2020 Did that. I replaced the solenoid also. I'm freaking lost. Could the regulator be shorted out? Wondering if it could backfeed. Share this post Link to post Share on other sites
rjg854 12,834 #4 Posted December 20, 2020 Is the PTO off Other safety switches working properly? 2 Share this post Link to post Share on other sites
SylvanLakeWH 30,509 #6 Posted December 20, 2020 1 minute ago, rjg854 said: Is the PTO off Other safety switches working properly? don’t ask me how I know... And to another a Michigander!!! Had an Aunt and Uncle that lived in Durand many moons ago!!! Share this post Link to post Share on other sites
Tc4276 0 #7 Posted December 20, 2020 Yessir. Pto is off. I have no diagram to show the other switches. I know of the seat switch, pto switch, brake switch. I believe those are all it has. I have no headlights to boot. Btw... Who are or were your relation that lived here? Share this post Link to post Share on other sites
Tractorhead 9,216 #8 Posted December 20, 2020 First things first to Go structured. Do You have an Meter aside? check first if Battery is fully charged. About 12,8V in idle check the Ground Wires if they be tight and clean ( derust under the Screws for good conduction) Search for Fuses, depending on machine there be differently Located. check the main Powerwire to Keyswitch. Check the Key Terminal B+ if there is Battery Power. Check the Ign Terminal on - key is in run position - it will see Power. if so check if Acc terminal on Key have power while key is in run position. Check the Clutch switch - if it have one - if it works and wires have good conduction. 1 Share this post Link to post Share on other sites
jmpianoman19 1 #9 Posted December 20, 2020 had the same issue on my C101 this week. No start. sat for 4 hours testing connections and wires. couldnt figure it out. replaced keyswitch, solenoid, start wire, voltage meter. Im lost. No idea what is up Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #10 Posted December 20, 2020 Power to one side of the ammeter and not the other? The ammeter has failed. Can you hook both wires to the same terminal? Does not matter which one. Or join the wires permanently and insulate the connection. Best repair is to replace the ammeter with a voltmeter but there is some wiring that needs to be changed. Garry 1 Share this post Link to post Share on other sites
Tc4276 0 #11 Posted December 20, 2020 I will try that... Thank you everyone! I will keep you all posted... Share this post Link to post Share on other sites
Maxwell-8 4,370 #12 Posted December 20, 2020 Try and put power directly to the starter. Check the battery cables, insure they are not lose at the connector. Have had the same problem and the ground wasn't secured to the battery clamp . Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #13 Posted December 21, 2020 On 12/19/2020 at 8:56 PM, Tc4276 said: Yessir. Pto is off. I have no diagram to show the other switches. I know of the seat switch, pto switch, brake switch. I believe those are all it has. I have no headlights to boot. Do you have the Briggs and Stratton engine or a Kohler engine? Hydro transmission or gear? Garry Share this post Link to post Share on other sites
953 nut 63,986 #14 Posted December 21, 2020 On 12/19/2020 at 8:29 PM, Tc4276 said: i turn the key on. Nothing. No headlights, no power as if it has no battery. Replaced the battery. Nothing. On 12/19/2020 at 10:52 PM, jmpianoman19 said: No start. sat for 4 hours testing connections and wires. couldnt figure it out. replaced keyswitch, solenoid, start wire, voltage meter. Im lost. No idea what is up Before spending money on parts it is important to determine which part isn't working. What we will be doing is bypassing components to see where the problem is. Take your battery to an auto parts store and have it load tested Use a pair of automotive jumper cables, connect the black one to the battery "-" and to a clean spot on the engine block, perhaps a bolt head. connect the red cable to the battery "+" terminal and touch the other end to the starter terminal where the cable connects. The starter should turn over. If the starter turned over move the red cable end back to the terminal on the solenoid that goes to the starter to se if the started turns over. If the starter turned over move the red cable end back to the terminal on the solenoid that goes to the battery and connect it there. Now take a small jumper wire from the red jumper to the small terminal of the solenoid, the solenoid should close and the starter turn over. If that worked then move the red cable to the other end of the battery cable and repeat the process. 1 Share this post Link to post Share on other sites
jmpianoman19 1 #15 Posted December 28, 2020 i ended up replacing the wiring harness as it is botched. if it isnt that then its 100% the PTO safety 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #16 Posted December 28, 2020 6 minutes ago, jmpianoman19 said: i ended up replacing the wiring harness as it is botched. if it isnt that then its 100% the PTO safety hopefully it works now. Can't stand no safety switch, i take them all out! I like the full control of my Horse. And reliability Share this post Link to post Share on other sites
