ebinmaine 77,358 #1 Posted December 14, 2020 I went to pick up a belt for Trina's 867 the other day and the only one they had available was a cloth-sided green equipment type belt which appears to be the right size but I have not tried to install it yet. NAPA part number was 3L330W Am I okay to use that or do I NEED to have a regular automotive rubber belt? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted December 14, 2020 Click on the fuzzy picture in the link. The information available suggest there are 2 different belt lengths so know which one you need. Garry 1 Share this post Link to post Share on other sites
squonk 45,536 #3 Posted December 14, 2020 Eric it will work, But, I find regular notched Automotive alternator belts work the best. More money of course but to me they work much better. I'll have the Napa # in a minute! 1 Share this post Link to post Share on other sites
squonk 45,536 #4 Posted December 14, 2020 Small Block Kohler Napa # 25-7320 .41" wide x 32.5" long Side angle 36 degrees Cross section HC41 Big Block Kohler Napa # 25-7345 .41" wide x 35.3" long side angle 37 degrees Cross section HC41 1 2 1 Share this post Link to post Share on other sites
ebinmaine 77,358 #5 Posted December 14, 2020 2 minutes ago, squonk said: Small Block Kohler Napa # 25-7320 . Super awesome. Thanks Mike. Share this post Link to post Share on other sites
wallfish 19,323 #6 Posted December 14, 2020 Rubber sided belt for the SG. There's not much belt to surface area on the SG pulley. 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #7 Posted December 15, 2020 (edited) I'll have to check out what I got when I ordered one for my Commando 8. I got an aftermarket "direct replacement" made by a company called D&D industries" off the evil bay. I didnt think this belt was as super critical like a drive belt or deck belt, so I went aftermarket. I think mine was not cloth covered, but also not notched. Edit: Belt is WH part number 1583, 3V 3/8 × 31-1/2 O.C. Edited December 15, 2020 by 71_Bronco 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #8 Posted December 15, 2020 The belt you have will work, but not as well as a rubber belt will. I've got one of the green cloth sided belts on the 753, same scenario I needed one that day and thats all they had on hand at the parts store. Most times it starts the tractor with no problems, but once in a while if the engine stops in just the right spot I will hit the starter button and the belt will slip for a second or so before it bites and cranks over. With the old rubber belt that was on it before I never had that problem Share this post Link to post Share on other sites
ebinmaine 77,358 #9 Posted December 15, 2020 12 hours ago, squonk said: regular notched Automotive alternator belts 11 hours ago, wallfish said: Rubber sided belt for the SG. There's not much belt to surface area on the SG pulley. 7 hours ago, HandyProfessor said: belt you have will work, but not as well as a rubber belt will Folks I checked the belt again and oddly enough it has one side cloth and the other is rubber. I'd say it's a cloth sided belt that was a touch out of spec and got "adjusted". Never seen the like of it. I'll swap for a notched one... Share this post Link to post Share on other sites
squonk 45,536 #10 Posted December 15, 2020 Cloth belts and "A" and "B" belts are actually "fractional horsepower" belts designed for electric motors 1 Share this post Link to post Share on other sites
ebinmaine 77,358 #11 Posted December 15, 2020 1 minute ago, squonk said: Cloth belts and "A" and "B" belts are actually "fractional horsepower" belts designed for **** I'd heard part of that... Ever seen a trimmed belt?? I've only been around belts since the late 80s.... Didn't know that was a thing. Share this post Link to post Share on other sites
