tallen4392 71 #1 Posted December 12, 2020 Before I start to rip things apart to try and find this noise anyone have any ideas ?? When it is sitting running there is a loud rattling noise when I depress the clutch pedal it goes away sounds like maybe a idler pulley any idea ??? Share this post Link to post Share on other sites
peter lena 9,535 #2 Posted December 12, 2020 TALLEN , you can remove the drive belt guard , giving you a total picture of the belt to pulley operation / function . from there some one else can work the clutch and you can zero in on the problem . having done a couple of those , its not a big job , its all out in the open . also a good opportunity to lubricate all frictional movement points . when those pulleys go bad they get wobbly and noisy . replace belt is its starting to fray .pete 1 Share this post Link to post Share on other sites
tunahead72 2,586 #3 Posted December 13, 2020 Sounds like an idler pulley about to self destruct. You may be able to hear it better if you have a helper operate the clutch pedal while you listen for the noise. Otherwise, do as Pete said and take off the belt guard, you'll be able to see what's going on much better. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,800 #4 Posted December 13, 2020 The belt will bounce on the bottom lip of the belt guard and make a heck of a noise. Replacing the belt or perhaps the return spring may help. See if the belt guard can be lowered slightly. Garry Share this post Link to post Share on other sites
