grinchsr 657 #1 Posted December 12, 2020 I know this has been covered before but I can not find it in the archives. Except for the throttle link and the choke lever is there any difference between the K341 and the M16 carb? Share this post Link to post Share on other sites
rjg854 12,847 #2 Posted December 12, 2020 Good question, I know I can't answer it, but I'm going to be looking at the replies Share this post Link to post Share on other sites
wallfish 19,323 #3 Posted December 12, 2020 A carb swap will run both types of those engines either way they are swapped around 1 Share this post Link to post Share on other sites
Bill D 2,598 #4 Posted December 12, 2020 Should be the same displacement engine. Either should work fine. Share this post Link to post Share on other sites
grinchsr 657 #5 Posted December 13, 2020 Thanks for the replies. They helped a lot Share this post Link to post Share on other sites
bds1984 1,506 #6 Posted December 13, 2020 I've swapped between the two without any issues as long as I remembered to switch the choke shaft otherwise your lever on your dash will be backwards; down is on and up is off or in is on and out is off. The carb on my K341 I bought new online (it was listed for an M16) and that is how I learned about the choke shaft differences. Share this post Link to post Share on other sites
bds1984 1,506 #7 Posted December 13, 2020 If you are buying one of the Chinesium carburetors, make sure you clean them out really good before installing them. On a hunch I opened one up and it was full of snot and black specs of unknown material. Other than that, the seven or so I have installed over the years, they all continue to run great. Share this post Link to post Share on other sites
grinchsr 657 #8 Posted December 13, 2020 I am probably going to buy from I-Save-Tractors if I can't get the current one adjusted Share this post Link to post Share on other sites
