John Sullivan 24 #1 Posted December 7, 2020 Any pros or cons on the driveshaft system on the 522XI ? 1 Share this post Link to post Share on other sites
JoeM 9,642 #2 Posted December 7, 2020 8 hours ago, John Sullivan said: driveshaft system on the 522XI I have several, no issues. 1 Share this post Link to post Share on other sites
Pullstart 68,944 #3 Posted December 7, 2020 I can’t find any cons... Vehicles have drive shafts... Pro’s? No belt wear, no slippage.. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #4 Posted December 7, 2020 Cub Cadet touted shaft drive for over 50 years with their horizontal shaft engines that should say a lot right there. 2 Share this post Link to post Share on other sites
JoeM 9,642 #5 Posted December 7, 2020 32 minutes ago, WVHillbilly520H said: Cub Cadet touted shaft drive And some of the better Cub models even had CV joints. All good with low maintenance. Just thinking, one con; drive shaft units are more of a challenge with implements. ie. toro tiller uses two belts to change the drive belt direction, as compared to the belt driven arrangements, motor turned 90 degrees, 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #6 Posted December 7, 2020 I've always thought the shafts were far superior to belts. They last longer and transfer power more efficiently. Cost more to build. Bigger WHs, Bolens, Power King/Economy. Cubs, and ... 1 Share this post Link to post Share on other sites
Skipper 1,791 #7 Posted December 7, 2020 (edited) Internally in the transmission, the only difference to the other newer WH models are (as far as I can tell), that the output from the hydro unit isn't a straight sprocket, on top of another ditto on the gearbox side of things, but a bevel gear setup, to take care of the 90 deg angle. So as far as the tranny goes, the driveshaft model should be just as strong and tough as any of the belt driven units. IMO, driveshaft is far superior. Pros: longevity and very low maintenance cost No noisy, rattling belt idler clutch setup No belt slip Easy usage of other end of engine for pto purposes Less collateral damage from broken belts. IE busted fan blades etc cons: You can't disengage the hydro unit, but seriously, has anyone ever used that feature? I mean, my car with an auto box don't have a just in case clutch pedal either Looks. We are used to seeing the engine orientated in the side pto fashion, and to many WH folks, that might just be how a true WH should look. No matter that better is available. just my and that's why I have an xi tranny in route for my next project. Edited December 7, 2020 by Skipper 1 1 Share this post Link to post Share on other sites
John Sullivan 24 #8 Posted December 8, 2020 (edited) Thank you everyone for your responses. I was thinking lack of slippage could be a bad thing. I have however purchased a 522XI which will be delivered tomorrow. It will be sitting next to my 1990 520-8,and 520H. Thank you all for your time, responses and once again guidance , John in Vermont Edited December 8, 2020 by John Sullivan spelling 2 Share this post Link to post Share on other sites
Goofey 89 #9 Posted January 7, 2021 On 12/8/2020 at 1:38 AM, John Sullivan said: I have however purchased a 522XI which will be delivered tomorrow. So how do you like your new toy Share this post Link to post Share on other sites
DennisThornton 4,773 #10 Posted January 7, 2021 On 12/7/2020 at 7:38 PM, John Sullivan said: Thank you everyone for your responses. I was thinking lack of slippage could be a bad thing. I have however purchased a 522XI which will be delivered tomorrow. It will be sitting next to my 1990 520-8,and 520H. Thank you all for your time, responses and once again guidance , John in Vermont I see you are not that far from me. I think I've bought more tractors in VT than NY. Perhaps we should stay in touch and watch sales for each other. Share this post Link to post Share on other sites
John Sullivan 24 #11 Posted March 14, 2023 On 1/7/2021 at 12:43 PM, Goofey said: So how do you like your new toy Just noticed this comment, I have mower deck and snow thrower on it. It has been heavily in use and held up well. The power steering is a nice option, Trying to locate or maybe build a fel for it. Apologize for the late response. Regards John 1 1 Share this post Link to post Share on other sites
