Mark Bartlett 83 #1 Posted December 5, 2020 Thanks to this forum and sharing members I making some progress on the dozer blade for the 312-8. I appreciate all the input and ideas todate! 8 Share this post Link to post Share on other sites
Ed Kennell 43,150 #2 Posted December 5, 2020 Wow, that's quite a project. Wish I could lay beads down like that. Thinking the left to right stabilizer would be more effective on the front attach-a-matic than the mid mount. 1 Share this post Link to post Share on other sites
Mark Bartlett 83 #3 Posted December 5, 2020 Yeah I know I'd get more leverage at the front mount. This thing is sort of heavy already, before I mount a blade on it so I was thinking about using the front mount for a heavy duty spring to take of lever effort from the operator. He will only be using this in dirt(don't get much snow just outside Houston, Texas). Share this post Link to post Share on other sites
Ed Kennell 43,150 #4 Posted December 5, 2020 For use as a dozer in dirt, the extra weight might be a good thing, of course you can use a solid lift link enabling down pressure. I have all hydro lifts,, so weight is not a problem. One thing I added to my stabilizer is a series of holes that I use to set a minimum plow height. It helps when grading and I use it when plowing my stone road. I just drilled 1/8" holes thru the vertical bar and use a flat washer and hairpin clip to set a minimum blade height. Share this post Link to post Share on other sites
Mark Bartlett 83 #5 Posted December 5, 2020 Yes, I got the need for the down pressure link in the build. Good idea re grade level control. Thanks!! Share this post Link to post Share on other sites
Mark Bartlett 83 #6 Posted December 26, 2020 Got back to my dozer blade project. I built a frame for the blade control actuator. It slides in and locks into place with the front attach o native hitch and has a rod (the handle in the pics) through it and the tractor frame. 1 Share this post Link to post Share on other sites
