WHX?? 46,840 #26 Posted December 5, 2020 1 hour ago, squonk said: you got the wrong Jim, Jim! Whose thread is this anyway?!?! We got too many Jimbo's here! My name is Jim. - YouTube 2 Share this post Link to post Share on other sites
Pullstart 59,819 #27 Posted December 5, 2020 I still don’t understand all the years you’ve been around Uncle Jim and you haven’t picked up welding... I the MIG is just filler and electricity. Clean metal, the right heat and feed rate, you’re welding! 1 Share this post Link to post Share on other sites
SylvanLakeWH 24,227 #28 Posted December 6, 2020 11 hours ago, WHX24 said: Whose thread is this anyway?!?! We got too many Jimbo's here! My name is Jim. - YouTube Hi... My name is Jim... Sometimes I’m called Sylvia... I like wheel Horse tractors... 11 hours ago, pullstart said: I still don’t understand all the years you’ve been around Uncle Jim and you haven’t picked up welding... I the MIG is just filler and electricity. Clean metal, the right heat and feed rate, you’re welding! Easier than making cheese curds... 2 Share this post Link to post Share on other sites
WHX?? 46,840 #29 Posted December 6, 2020 (edited) 40 minutes ago, SylvanLakeWH said: Hi... My name is Jim... Sometimes I’m called Sylvia... I like wheel Horse tractors... True... that ain't exactly haiku tho... Quote Easier than making cheese curds... Not true yer a cheesehead! Edited December 6, 2020 by WHX24 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,627 #30 Posted March 22, 2021 On 12/4/2020 at 5:05 PM, elcamino/wheelhorse said: wonder if rivets would work ? Don't know how to weld or brazing . If you were worried about the rivet not being strong enough or you only had aluminum rivets that may wear....IN lieu of a rivet, you could "bolt on the bolt" with a smaller bolt. Just have to be sure the head was thin and smooth and place it to the inside with the nut on the outside.Maybe even grind the bolt head down a bit thinner. Share this post Link to post Share on other sites
